Is There a Way to Show VCA Masters
both on the iPad app and the PT screen when you select the Show Tracks in Group soft key?
Ellis Beckwith iMac (mid 2011), Intel Core i5 2.5 GHz, 32GB; Samsung 500Gb SSD, PT 2019.5.0, Avid Control; M-Audio Oxygen 25, Faderport 1 |
Re: Is There a Way to Show VCA Masters
What you describe sounds like VCA Master Mode on the S3. I don't think it's possible on the iPad app alone. But you can achieve the same result by making a number of Layouts that have the VCA masters and the associated tracks from a group. That's your best bet. Layout switching on the app is easy and powerful.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
You can filter by Track types on the iPad/Control App so you can just show VCA's
If I had an S3 and spilled a VCA onto it's surface, would the PT mix window on my computer show the tracks in that VCA along with its master?
No, those tracks can be any in the PT session and PT only shows tracks in order. The upcoming Folder Tracks may help you with this kind of workflow
For now, I can just select all the tracks I want to see (including the VCA Master) and press Show Selected Tracks. I was just looking for a one-button solution due to laziness. Still haven't figured out why I would need to see the VCA Master along with the spill...
To control the overall level of the group.
I understand that. Just that, as I'm balancing the elements within the group, I shouldn't need to see the master on the screen. Only after getting a group balance should I need to see the master to balance aginst the other groups.
Or am I not understanding the purpose of VCAs? They're just to simplify the console for the final mix, right?
I think (and I do) people like to be able to have quick access to both at the same time.
Thus the reason I was trying to find a way to see both the spilled group and it's VCA at the same time. Does this seem like this would be something that might be available in a future update? I can see that for those that have Docks and S1/S3's this would not be an issue at all.
Masters | Chickenhawked | General Discussion | 23 | 05-20-2013 02:33 PM |
Loading show files in SHOW mode? | fohluke | VENUE Live Sound Systems | 2 | 03-29-2012 11:46 AM |
Pro Tools/D-Show standalone integration idea with D-Show show files/virt. soundcheck | digidesigner | VENUE Live Sound Systems | 2 | 11-08-2011 02:52 PM |
192 Masters | zoggied | Tips & Tricks | 4 | 04-10-2003 02:17 PM |
EQ masters, how!? | smcoptyltd | Tips & Tricks | 1 | 11-06-2000 05:35 AM |
