Old 03-12-2001, 06:29 AM
cazfair cazfair is offline
Default protools freezes/hangs/crashes/etc after about 20-60mins
As the subject line says, pro-tools le hangs
after a period of time of normal operation
or even if ive left it there for a bit to go talk to the band etc
symtoms.
the mouse pointer locks up(but i can still ctrl/alt/del out of digi,even ask's if i want to save it???)
if im recording/playing back, the track counter keeps going but the recording /playback stops?
My system-
P3 733mhz..
asus CuSL2-C
256 meg pc133 ram
sound blaster live value
asus v6800 dlx
etc etc etc
i have recently taken everything of the start-up ..so only the bare min is running.
i havent had digi for long and havent had a problem until now,probely because i havent had it running long enough but now we are recording in a studio with it and its giving me gip.please help us!
p.s i do own a pair of steel caps!
cheers.....
steve bond
cazfair studios
Old 03-12-2001, 10:31 AM
crs117 crs117 is offline
Default Re: protools freezes/hangs/crashes/etc after about 20-60mins
what kind of mouse do you have, and what kind of connection does the mouse use. I am questioning if pt is actually locking up or if your mouse is temporarily locking up. I know that some usb mices have had some problems in the past, but i have not heard anything since about last summer i think.
Christian
Old 03-12-2001, 05:37 PM
jeziel jeziel is offline
try disable any video aceleration, here is working
Old 03-13-2001, 11:53 PM
ReniuR ReniuR is offline
Check to make sure your computer isn't over-heating.
it sounds to me like too much heat is building up in there. If it's in a safe enough place, go ahead and open up the case, spot a little fan at it, and you may have better luck...
just a suggestion...
(I run my box with one side open all the time, and a fan pointed at it when I'm really racking it. The fan helps out a lot, even just on low, anything to keep airflow is never a bad idea.
[This message has been edited by ReniuR (edited March 13, 2001).]
-ReniuR
www.disposableproductions.com
Old 03-16-2001, 12:47 AM
Cheers thanks to crs117,jezeil and ReniuR for
repling to my problem and it was overheating
that was the problem,its still summer in australia and this was a big problem in an unairconditioned studio.....I took the side panels off and placed a fan pointed at the cpu and only had one crash(as opposed to 10)
in a 10 hour session....next im gonna have to look at a better cooling system for the cpu.........
again thank-you ppl
cazfair studio's
Old 03-16-2001, 08:04 AM
Locke Locke is offline
User conference is awesome!
Old 03-18-2001, 03:27 AM
cmink cmink is offline
You might want to make sure your 001 isn't sharing IRQ settings especially with your video card. Mouse kept locking up until I fixed this.
Old 03-18-2001, 05:57 AM
techos techos is offline
hello. put a golden orb or a chrome orb (easier to install) on that pentium. buy one at ebay for $9.95!! works well. alsoan exhaust fan could help. these are inexpensive as well. they usually install in a open port or bay.
tony
http://www.weragazzi.com
PT10.2 Hangs & Freezes uponSave, Mt.Lion 10.8.1 imdrecordings macOS 1 08-28-2012 08:44 AM
Protools 8.0.1 intermittant freezes and hangs Phill Barrett Post - Surround - Video 18 10-30-2009 09:04 AM
Recording Midi freezes hangs Pro Tools jallen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-26-2007 06:17 AM
Opening Session Hangs/Freezes System ptal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-29-2006 01:34 PM
hangs/crashes soundhealer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-20-2003 12:48 AM
