How to erase CD-RW with Toaster
confused: I'm using Toaster 4.1.2. My problem is I can't find the right path to erase CD-RW. Can someone tell me about this? :
Re: How to erase CD-RW with Toaster
Put the disc you want to erase in your CD-RW drive, open Toast, and go to Recorder-->Disc Info.
There should be a prompt in there that will allow you to erase the disc.
One good thing about music: when it hits, you feel no pain. --Bob Marley Rig: MacBook Pro (15,1) 6-Core i7 2.6GHz / 32GB RAM / OS 13.5.2 / PT 2023.9 / Waves Horizon v14 / iZotope Music Production Suite 4.1 / Focusrite Clarett 4pre USB / Apple SSD AP1024M 1 TB (System), Samsung T5 SSD 1 TB (Audio) / Cal-Digit TS3 Plus TB3 Dock / Genelec 1030A Monitors |
.....20 years later your disc will be ready
[img]images/icons/grin.gif[/img] |
Exactly! Is so useless cuz it takes so long, I just use cdrs and bite the extra 50 cents if i need to redo a backup or something... CDRW erasing thru toast is a joke..
I ve used DirectCD and that works better, but only computers with than extension can read the discs.. what a drag.. anyone know of any worthwhile cdrw burn/erase progs that dont take 20 years? MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
Well...if you use the same CD-RW with Toast again, you can choose that option, and it only takes a fraction of the time.
Didn't 4.1.2 have the quick erase option? all you need to do is wipe the directory to reuse the disk
Been awhile so i don't remember! The long form erase is the same as doing a low level format on disk and considering how slow cd-rw's are yes it will take some time.
Bill Conners Creative Director 99-5 WGAR/Majic 105.7 Cleveland, OH |
best SATA dock with FW 800? (toaster style) | MixerGuy | Pro Tools TDM Systems (Mac) | 4 | 08-15-2010 12:15 PM |
how do you erase all automation? | riotbeats | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-12-2005 12:49 AM |
extract audio tracks with toaster or record on pt via ADAT BRIDGE ON A 24 BIT SESSION | Alécio Costa | Pro Tools TDM Systems (Mac) | 7 | 02-05-2002 07:36 PM |
ERASING CDR-W with MAC 8.1/Toaster... | Alécio Costa | Tips & Tricks | 1 | 02-03-2002 07:47 AM |
Erase All Automation | felixstone | Tips & Tricks | 1 | 03-06-2001 12:38 AM |
