Old 08-27-2007, 03:04 PM
right beside right beside is offline
Default acceleration question!
I am working on the intro to a song. It is supposed to gradually get faster and faster. I have a bunch of regions in place that make up a loop that is the backbone. Right now the loop repeats at a steady tempo. Is there a way to put the accelerando in the timeline so that the grid changes, but also so that the regions stay locked to their respective grid lines and move with the grid and tempo changes? Thanks in advance.
System Details
Old 08-28-2007, 06:41 AM
mindnoise mindnoise is offline
Default Re: acceleration question!
HI,
with sample loops you either have to adjust the length manually with TC/E to each acceleration
or use a sample slicer to let it adjust automatically.
Try Synchronic (demo) from digideisgn. It just does what the name suggests and does it good:
Keep a loop in synch with the tempo. If you like it, the ilok-icence goes cheap on ebay.
BTW you know how to make tempo maps in PT? if not consult your PT Reference Manual.
Audio regions will not adjust to the tempo changes automatically, MIDI will do.
regs
last: PT11.3.1
Old 08-28-2007, 09:17 AM
td.Lemmon td.Lemmon is offline
hi there,
When you create an audio track you can choose between a "sample based" and "tick based" audio track.
When you choose "ticks" the regions will behave as if they were midi
(with their audio limits, of course)
and will move with a tempo change.
In this way it is easy for you to experiment with different speeds.
You can also change the "samples" or "ticks" later.
At the left of the edit window, in your track there's a small metronome icon
(I think it's green, but I am unsure).
Click it and choose either...
Hope this helps,
cheers
One + minus one = zero
Old 09-02-2007, 09:38 PM
thanks guys. the difference between sample and tick based tracks is what i think i am looking for. i want the regions to act like midi and follow the timeline. i'll try it tonight. thanks again.
System Details
Old 09-03-2007, 12:31 PM
that was it. i knew it had to be something simple. thanks.
System Details
CPU vs hardware acceleration Mack Truck macOS 2 02-06-2012 05:40 PM
File Acceleration Testing BroomPole Post - Surround - Video 0 02-03-2012 12:09 PM
knob acceleration adjustment robertg Artist Series 9 11-18-2011 06:22 AM
Pro-Tools LE and Acceleration Cards. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-29-2009 12:18 AM
Beige G3 acceleration Larryboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-05-2002 01:25 AM
