need some tips / thoughts here ....
I'm thinking of expanding my system to do the following,...... :
I want to have more analog in/outs to hook up more analog gear : dynamics / eq ..... without having to re-patch all the time. The 888/24 's being hell expensive just to add analog insert / inputs , Ad8000 out of the question ...... still, I don't want to compromise by going 882/20 ....... Currently I'm looking at : Adat Bridge, which would give me a 16 ch / 24 bit lightpipe to PT in combination with one rme interface to start with, possibility to hook up second one later on ..... : http://www.rme-audio.com/adi/adi8ds.htm any other thoughts / ideas / tips ???? Again, I want to keep it 24 bits , 96k would be nice for future .....and ofcourse less expensive than 888/24. TIA ------------------ Chris Lambrechts
Chris Lambrechts Applications Specialist- Live Sound |
Re: need some tips / thoughts here ....
I use the RME/ADAT bridge solution for analog inserts.
Very happy with it Low latency too!
www.olipoulsen.com iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7 Apollo 8 / PT Ultimate 2020.9.1 |
anyone-else-bumper
------------------ Chris Lambrechts digi, is this one OK ??? (no I'm not a member or employee there, I don't even know them but they try to add their 2 cents ............ and I support them doing that) http://www.copyrightcontrol.com/Clients.asp
I belive the 24 bit ADAT bridge is out & the upgrade service for old one is 'on line'.
??? Jules |
Jules,
The 24-bit ADAT-bridge is out, it's sitting in my rack next to me. Speer, the RME will most certainly be used to interface analog gear. As Chris knows, I got the same setup: ADAT bridge and 2 RME ADI-8 Pro. It gives flawless results. Also, the RME has a TDIF interface. I connected a TDIF > 4xAES interface by Tascam to it, and now I can also insert 4 digital effects via AES, so the 888 is no longer necessary. But I agree the old ADAT bridge will only pass 20 bit so putting a 24 bit AD/DA converter in front of it might be a waste. Cheers Arthur |
Speer,
Digi did post an announcement on the 24 bit upgrades here and the upgrade price is $295 per unit. I just had two of mine done two weeks ago and they turned them around in 24 hours. Total bill $590. I have both the RME and the Alesis units (and AD-8000's.) They both work fine. I use the Alesis for reverbs sends and returns and the RME for analog compressors and eq.
JKL |
Thanks, LansRec.
I went to Digi's "hardare upgrades" page. It says $795. Someone at Digi must have made a mistake. This is very good news. Maybe Digi has turned a new leaf after all. This is just in time, too, as the Kyma Capybara will soon have lightpipe support, and 24-bit Gigastudio cd-r's are starting to happen. |
mmm, thanks a lot Allan, missed that one ......
<BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Originally posted by Speer:
Probably a minor difference, but it looks like lightpipe may indeed be inferior to AES. Bummer.<HR></BLOCKQUOTE> Not that much of a bummer. The jitter caused by the lightpipe was presumably due to the DA attempting to slave its clock to the lightpipe input. In a PT setup where all pertinent devices are slaved to a single ("house") clock, this is not as significant an issue until you start losing data. I regularly use a 5m lightpipe for transfers into PT (and a 5m BNC cable for wordclock) without any problem whatsoever. This is the "cheapo" brand too, so I imagine with monster I could double the length w/o worry.
Cheers, Angelo Quaglia |
$795 is the price of the original 16bit nubus adat bridge to the current one, i believe.
and you can use an adat bridge and rme unit for INSERTS? as in, in and out at the same time? do you slave it to a master clock source? |
Mixing in Reason vs Pro Tools Tips or thoughts | bryced87 | Tips & Tricks | 16 | 05-23-2016 03:15 PM |
Used Mac thoughts | Kachunk | macOS | 6 | 03-20-2012 10:52 PM |
10 loaded/my thoughts and tips for downloading | bonzerboy | Windows | 2 | 10-22-2011 11:31 AM |
PT8 LE and the new UAD 2. Thoughts and Tips | kmat04 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-20-2009 12:29 PM |
My thoughts on being new to Mac and PT8 | H-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-02-2009 08:48 AM |
