Re: interface white noise
I have 2 16x16 interface and they were connected in daisy chain and I was having an issue with inputting an external instrument like bass or guitar it would cut out intermittently,so I disconnected 1 of the interface and everything worked like it should, my question is should I get another digi cable and use the other input on the card or what??
any help is appreciated. Thanks
JAMAICAN I IS 2008 2009 and 2010 Mac Pro 8 core with 64 GIG memory with 9 terabyte of hard drive space blue ray player HDX 1, 2 16X16 interfaces sync I/O. |
What I would do first would be to swap the digilink cable from the setup that works to the cable you disconnected and see if the problem returns. If it doesn't and still works okay then the cable isn't the issue but maybe one of the ports. You could try running the two converter boxes into separate connectors on your interface card.
Are you running a preamp or some such between the guitar/bass and the converter? |
A thought - do you have the word clocking and loop sync connected properly? I'm assuming you're using Avid converters right? If so are they the HD I/O? |
Ok, so it all seem to be working right.
Alright! Let's hope it continues to work out okay.
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini | Bigpit | Windows | 1 | 09-09-2013 09:26 AM |
Burst of noise (not necessarily white noise) at the end of clips | Swarf | macOS | 9 | 09-20-2012 08:55 AM |
White noise only with aux in | huggles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-03-2010 10:22 AM |
Static noise (aka White noise ) During playback. =/ | PoPimp3069 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 03-23-2010 04:06 PM |
Pink noise vs. White noise | kcarter | Tips & Tricks | 9 | 08-29-2001 10:42 PM |
