#51
Re: 10.13.6 with 2018.7 ... best version ever!? Holy Sssh
Yes, the "freeze" is on the startup screen, when it says that it's setting up MIDI devices. Just stops for 45 seconds. I don't think this is a ProTools problem as such though because I get the same delay opening up Live. I'd guess something in the MIDI subsystem? I'll do a bit of digging around. I have installed the latest 10.13.6 sup 2 update. Couldn't see a reason not to as it was brand new out of the box. I did this before installing everything, which took an age.... Haven't had too much time yet to test how things are but I'm not seeing a great deal of difference in cpu usage at different buffer sizes. This is a big difference to what I saw on previous versions. And I'd just got used to playing slightly ahead to compensate for that extra latency... The only problem I do have after installing everything is that Structure doesn't have anything in its database. I can find the samples and instruments and these load up fine. If I go into Database it says that it's building the database and this could take some time. I think we're talking time in geological proportions here because I've left it for ages and still nothing. This is particularly dumb as I've run the disk speed checker on that drive and it's reading and writing at close to 3GB/s. Leaving it for an hour means that it could in theory read over 10TB and I don't think that the Structure library is quite that big!. If it is I'd like to know how it fits onto the drive... |
#52
Well I am scared to update from 10.13.3 unless Avid reallly gives us the green light !
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.4.1 Pro Tools 2024.3.1 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
#53
Yes, 10.3.6 works flawless like yosemite. This OS update and PT 2018.7 is the best setup since a couple of years. I hope they will be able to fix the rounding error at least on midi clips that drives me crazy
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
#54
whats going on here :)
Avid says that 10.13.4 is not qualified because of CPU overloads and all the people here says exactly the opposite. :) maybe I will give 10.13.6 a chance. But I don't think it solves the CPU spikes with big plug in chains on masters. that would be too cool. |
#55
2) I think I am reading conflicting reports here on Buffer setting improvement. Has anyone found that the latest OS-PT combination has forced the buffer setting to be higher than previous versions? Big thanks. |
#56
Have you tried systematically removing third-party plugins from your system until the problem potentially disappears? In the past, when I've heard about CPU spikes at high buffer sizes its due to a plugin that needs to be updated or removed (remember, you can experience CPU spikes due to a plugin that is simply loaded when Pro Tools starts; it doesn't have to be inserted in the session.) |
#57
Has anyone tried to play russian roulette and survived?
#58
Sure, this would be an apt analogy if one was able to start up one’s body from a different partition.
Ben Rubin Producer//Mixer//Bassist//Composer benrubin.com ------------ PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive, Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1 |
#59
You should convert to APFS only if you use SSD, not with HD
#60
Does anyone else have more info on if 10.3.6 and PT 2018.7 is good to go?
PT 2021.12.0 w/Focusrite 2i2 iMac i7 3.8GHz / 72GB RAM / Mac OS X 12.1 https://linktr.ee/sergius128 |
Is Pro Tools 2018 EVER going to be supported on a current Version of High Sierra? | off the wall | macOS | 10 | 01-05-2019 04:53 PM |
Macbook Pro 2018 w/ UAD Apollo 8p and PT 2018.7 Performance Issues | Dudiester | Pro Tools 2018 | 5 | 08-12-2018 08:33 AM |
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations | matthewmkb | macOS | 0 | 06-27-2018 06:33 AM |
Permission Denied (13) on Launch -Pro Tools 12, Version 2018.1 | Randroo | Pro Tools 2018 | 7 | 05-07-2018 08:11 AM |
Does the 2018 boxed version come with iLok 2 or 3 and ... | rique000 | Pro Tools 2018 | 3 | 02-23-2018 06:11 PM |
