Old 02-03-2004, 01:55 PM
besmusic besmusic is offline
Default 2 MB or 8 MB cache on external drive?
Is there a realized benefit in PTLE using 002r for the 8MB cache? Any recommendations?
Pete Turok
Powermac G5 dual 2.0 & Dell i8600
PTLE 6.2.2, 002r
Old 02-03-2004, 03:43 PM
where02190 where02190 is offline
Default Re: 2 MB or 8 MB cache on external drive?
The apps workings, wave draws, file caching, etc are a bit faster with the 8mb cache drives. there's little difference in price these days, and it can't hurt. The WD Caviars seem the fastest, the IBM/Hitachi's almost as fast and much quieter.
Old 02-03-2004, 04:09 PM
hurdy gurdy hurdy gurdy is offline
I second the notion:
Those WD drives are pretty hard to beat for the price. Quiet, fast, reliable, and just dang cheap and rugged.
L.A.Branville
Old 02-04-2004, 11:15 AM
3JDamon 3JDamon is offline
It's usually best to disable the drive cache for Protools, but the 8mb cache is better for other operations.
Old 02-04-2004, 11:20 AM
3JDamon,
Can you explain why? Obviously conflicting advice above. I know digi says there's no benefit...how do you disable the cache just when working in PTLE? Have you noticed a specific benefit in doing this?
thx so much,
Pete
Pete Turok
PTLE 6.2.2, 002r
Old 02-04-2004, 11:26 AM
lemix's Avatar
lemix lemix is offline
Hmmm...
Aren't you referring to the Windows implemented allocation of read/write cache here ??
How can one disable that 8Mb of RAM, which is actually residing on the HD's controller board ??
And why ??
Allen...please...
cheers,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 02-04-2004, 12:02 PM
I had the same question, but then I did some searching.
It's hard to find documentation, but I read something on the MS website recently which suggested the Windows disk drivers know how to enable/disable the buffer on the EIDE drives.
Quad 2.5 G5, 4.5G RAM
Old 02-04-2004, 12:13 PM
lemix's Avatar
OK,
But why though ?? Has anyone here actually compared disc performance between two identical models ( say...WD 80Gb ) with 2 and 8 Mb on board ??
I'm really interested in knowing the results.
cheers,
cheers,
Andrew
Old 02-04-2004, 01:42 PM
3JDamon claims (I think) to have done enough testing to be convinced. I haven't, I leave it enabled, no problem on my sessions so far.
Intuitively, I think it should be helpful. Practically, it's really hard to devise a test to actually quantify the performance effect, since we don't know exactly how PTLE accesses the disk in normal use, and the DAE buffer setting is also involved.
But the 8mb buffer on the drive should decouple (somewhat) OS file writes from the actual commitment to disk, which should make file writing very fast, up to a point. As the write rate approaches the physical disk write rate, any benefit should diminish.
Enough theory and speculation. Install a drive, try it both ways, use whatever works.
Old 02-04-2004, 01:47 PM
lemix's Avatar
Allright...let's do music...have a Guinness...or a few...
cheers,
Andrew
External Hard Drive Disk Cache drumzalicious macOS 0 06-09-2012 10:16 PM
FW drive cache size drmmrboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-02-2007 11:01 PM
External FireWire Drive With 16 Meg Cache Buffer coolcat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-18-2006 07:19 AM
Hard Drive - 8mb cache or 2mb?? Sonicvalley Pro Tools TDM Systems (Mac) 4 02-28-2004 04:46 AM
8mb cache ide hard drive... da BaSsTaRd! 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 09-20-2002 01:32 AM
