Old 07-09-2000, 08:29 AM
zboy2854 zboy2854 is offline
Default Motherboards again
This question is directed toward Digi tech support. I'm going to build my own system to run Mix Plus. I've read threads here mentioning other motherboards that work, including Asus P3BF and IWill DBL 100. However, the only approved board listed in the compatibility documents is the SE440BX. I'd like to use a motherboard that has more PCI slots for future expansion with additional farm cards, etc., and the Intel only has 3 PCI slots Are there any others, possibly the ones above that are specifically approved by Digidesign? Thanks.
[This message has been edited by zboy2854 (edited July 09, 2000).]
Old 07-09-2000, 01:47 PM
DigiTechSupt's Avatar
Default Re: Motherboards again
zboy2854
I cant really give any information on this
issue(I dont know) I will at this point leave
it up to other users to provide personnel experience about what they are using to answer
the question. I will look into the possibilty
of getting more info on recomended mothere boards. http://www.digidesign.com/compato/pt24perfnt.html
MJ
Digidesign tech Support
Avid Audio Tech Support
Support FAQ
Old 07-10-2000, 03:00 AM
tonygoodall tonygoodall is offline
Asus P3BF has 6 PCI slots!
(works with mixplus OK, with 650MHZ P3)
tony
Old 07-10-2000, 06:01 PM
Juscelino Alves Oliveira Juscelino Alves Oliveira is offline
[QUOTE]Originally posted by tonygoodall:
[B]Asus P3BF has 6 PCI slots!
tony,
Could you tell me which the complete set up (hardware) do you have? ( very sorry my poor english...)
Thanks
Du Oliveira
Old 07-11-2000, 09:18 AM
I have :
mixplus running on:
Asus P3BF
Pentium 650 (Slot)
256MB SDRAM running at 100MHz
ATI xpert @ play video
Iwill 2930 UW SCSI (Advansys chip)
IDE boot drive
IBM 18GB UW scsi drive (for audio)
I have tried the old MusicQuest MQ16 as a midi card, but I'm lookig to get an opcode 64x instead
I've tried the cards in
PCI slots 1/2 - OK
PCI slots 4/5 - OK
PCI slots 5/6 - OK
on the ASus P3bf, pci slot 4/5 share IRQs,
and I think pci slot 6 shares with 1
It's great to put the digi cards further
down the motherboard, as I can actually
mount some hard disks in line with Slot 1-3
(as the mixplus cards are very long!!!!)
another warning - the digi cards have a long backplate, that can make it difficult to insert them all the way at the back of the motherboard
good luck
tony
THe only fault is I'm getting occasional DAE 87 errors, But I think the audio drive's NTFS partition is odd, sometimes I can't copy files into it
- -the DAE 87 errors were because PT went back to using the IDE boot drive, and ran out of space!!!
[This message has been edited by tonygoodall (edited July 24, 2000).]
motherboards silk General Discussion 0 08-09-2003 05:49 AM
some motherboards, anyone ever used any of them?... SixChurchStreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-03-2001 08:23 PM
New Motherboards JFogarty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 12-03-2001 06:34 PM
Motherboards... Walling1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-04-2000 08:06 PM
more (yes more) on motherboards musicfest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 07-24-2000 12:49 AM
