Play button issue after firmware/6.4 update
Has anyone run into this? When I hit the play button on the 002 - sometimes it will play a frame and stop or it will play as normal or not at all. I have to hit the button at least twice to launch play.
Anyone?? Thank you, |
Re: Play button issue after firmware/6.4 update
Anyone? LOL
Yea, I've had the same problem intermittently after upgrading to 6.4 using an 001. It will work ok for a while and then go nuts exhibiting the symptoms you describe. There was a post around here at one time that said something about a sticking key on the keyboard. You might want to do a search.
Good luck, Jack |
Music won't play. Play button flashes and Stop button lights up | Mattitude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 04-16-2020 03:03 PM |
Strange issue with button PLAY | tristan klein | macOS | 113 | 02-03-2015 04:33 PM |
C|24 firmware update issue and misc. routing ?'s | VIStudios | Pro Tools 9 | 7 | 11-21-2010 12:56 PM |
PT8 SYNC HD firmware update issue | JThelin | Pro Tools TDM Systems (Mac) | 4 | 07-03-2009 09:05 AM |
Digi002 Firmware update issue | _ron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-03-2005 03:51 PM |
