Old 09-03-2018, 09:36 AM
vernon vernon is offline
Default Cheap plastic headphone jack and etc
Well i bumped it and stripped the threads. I took the cover off and saw its probably an easy replacement with the plug in to the pcb, BUT !!! I dont just want to haphazardly just throw something in. So I am wondering if anyone knows of a better replacement part.
I am actually impressed by the sound capability in this unit, its pretty tweakable and its pretty user intuitive, i didnt have to really even use a guide to get it started. One issue is when it is on for a while as an external sound card for my mac, streaming videos , it drops out, so im not sure if thats an output setting or a high sierra setting.
AES, SPDIF ??? so to get a full 8 on your simultaneous I/O, what is your go to? And I found its tracking capabilities online but lost them , IIRC 48 tracks max? anyone have that info?
Lastly, Ive read reviews that it doesnt do metal, before i purchased it, then i tweaked it and got metal, 2 percent rule there. Anyway was anyone else put off by the sustain killing gate settings on this in the presets? Is there a reason they are so constrictive to sustain or are those meant as rhythm settings?
Music Production Bachelor of Science, Fullsail Univeristy, 2016. Mid 2012 MacBook Pro, Eleven Rack , ProTools , Logic, Sibelius, etc.
Old 09-03-2018, 09:44 AM
Default Re: Cheap plastic headphone jack and etc
Also, whats the best solution for using two monitor setups, I was thinking of cabling splitters until i thought about various electrical factors. I dont think a monitor controller is going to be best since i usually run both at the same time,BUT i can see a use for a controller and switching between pairs.
Old 09-03-2018, 12:19 PM
Benoni's Avatar
Benoni Benoni is offline
If audio drops out, is this after the computer has been asleep? It is recommended to disable all sleep and suspend settings.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 09-03-2018, 12:34 PM
I disabled sleep, the driver drops in use, as in cuts out when streaming. Ive been rebooting the device and for the most part it works until it doesnt work, then its reboot the system.
Blown 11r headphone jack BIG_AL_SHREDDER Eleven Rack 4 11-10-2017 06:03 PM
MBOX Pro headphone jack B CowboyNeal FireWire & USB Audio Interfaces (Mac) 1 02-13-2017 08:23 PM
Headphone jack broken. Philuk Eleven Rack 6 07-28-2013 07:36 PM
002 headphone jack tym cornell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-29-2009 09:10 AM
Headphone Jack Malfunctioning Hellgi ProControl, Control|24, Command|8 0 07-07-2008 04:07 PM
