Old 10-02-2019, 12:02 AM
ulisauer ulisauer is offline
Default Powering off S3 crashes Eucon
Hi there,
we're having the issue that when a S3 unit is switched off, the other workstations EUCON within the network crash. Note that the unit that is switched off was not linked to the crashing workstation, it's just in the same network.
W10 workstations in windows network
Anyone else?
Thanks.
Old 10-02-2019, 08:25 AM
EddieJones's Avatar
Default Re: Powering off S3 crashes Eucon
Are they all on the same EUCON version ?
Old 10-02-2019, 10:38 AM
Correct. 19.7.
Old 10-03-2019, 07:11 AM
EddieJones's Avatar
We obviously test this extensively here, but went back and retested and can't reproduce this. Are you 100% sure you don't have an old EUCON on a machine somewhere
Old 10-03-2019, 05:27 PM
mattrixx mattrixx is offline
HI Eddie..
I just reproduced this just now. Power cycled the S3 to fix a couple of the OLEDs, which were doing that weird split display thing, that I have reported previously. (occurs after a little while and needs a power cycle of the S3 to get them working correctly again).
Anyway, I've reported it in the crash reporter as it happened. So hopefully you'll have that come though shortly.
Cheers,
Matt
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 10-04-2019, 10:11 AM
EddieJones's Avatar
We found the crash dump in our system and wrote up a bug. Thanks
Old 10-04-2019, 10:28 AM
BrianGasacao's Avatar
BrianGasacao BrianGasacao is offline
Originally Posted by ulisauer View Post
Hi there,
Anyone else?
Thanks.
@ulisauer - On all your Eucon workstations, what setting do you have in EuControl Surface tab for 'Automatically Add:'? Is it set to 'All Surfaces' or 'My Surfaces'?
Old 10-04-2019, 02:14 PM
It is set to ‚My Surfaces Only‘.
It just crashed again, I sent you a crash dump.
Old 10-07-2019, 10:59 AM
You can download the "crash.crash" zipped here
Please advise.
Old 10-09-2019, 12:17 AM
Hi Eddie,
No, there is no other computer in the network with an old version of eucon.
Nuendo 8 crashes EuCon blue moose Artist Series 1 08-12-2019 09:31 AM
Eucon crashes planck Avid Pro Mixing General Discussion 23 09-14-2018 09:20 AM
Cubase 9.5 crashes, when using Eucon 3.7 pivomaniac Artist Series 0 12-21-2017 01:25 PM
EUCON 3.7 crashes immediately!!!!! PT user Avid S1, S3, Dock and Control App 50 11-04-2017 09:54 AM
eucon 3.0 crashes tandri79 Artist Series 7 06-24-2013 01:24 PM
