Old 07-12-2013, 08:14 AM
lorenaguey lorenaguey is offline
Default SC48 pops when linking or un linking stereo channels
The weird thing about this is that we had a separate monitor desk, and the SC48 at FOH was causing a pop through ALL the monitors with the input faders down.
It also briefly mutes the desk. As in I had a super quick line check and didn't get around to linking stereo keys until after they started. Pop through the wedges and split second mute of everything at FOH. After the show was over for curiosities sake I unlinked to see if it would happen again, sure enough, another pop through the monitors.
This was with a passive split, one going into the mix rack, the other tail going into the monitor desk.
Is this normal on this desk? I guess I never noticed it before because usually my channels would be linked ahead of time.
Old 07-12-2013, 08:51 AM
Brent Lind Brent Lind is offline
Default Re: SC48 pops when linking or un linking stereo channels
This is normal behavior, and the reason the linking function requires you to put the desk in "config" mode. Config mode is required for any function that may interrupt audio and is thus not a good idea during performance. The fact that it affected monitors is simply because it was on a passive split. An active split would likely have popped in FOH but not monitors. This is not to say a passive split is a bad thing, it's just a workflow thing to remember in the future.
Old 07-13-2013, 04:59 AM
Dsturzy Dsturzy is offline
I have seen some SC48's that pop and some that don't. They have been in stand-only configs and also passive splits. Do we know why some pop and some don't? I checked and all were on the same firmware.
Old 07-13-2013, 08:19 AM
Thanks Brent. Can't say I'm too pleased about that though. I've never been on another desk that does that, but oh well.
Old 07-15-2013, 11:38 AM
xcx xcx is offline
i recently had a show where i could run the mix via aes/ebu to the pa-amps. did not pop when stereo'ing and de-stereo'ing channels. btw, my console usually pops when linking/breaking pairs on analog outputs
Old 07-15-2013, 02:13 PM
There are many variables and possible variations but what's important to remember is that you should really have all outputs muted when performing any functions requiring "config" mode. IMO it's preferable to mute beyond the console (i.e. at crossovers, system interfaces etc). Always better to be safe than sorry.
Old 07-15-2013, 05:25 PM
Brent on the desk that I was at that popped, it didnt matter if outs were muted or not. Still popped. In my opinion that's completely unacceptable. I am fine with audio dropping during my Pre show setup, but popping...
Old 07-16-2013, 08:11 AM
xcx xcx is offline
maybe unpatching outputs does prevent poping when linking/unlinking. but yes. the poping sucks a little to be honest.
Stereo panner linking mattyharm Pro Tools 9 2 01-25-2012 05:41 AM
Stereo linking mono plugins? Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-31-2008 07:45 AM
Pan Linking of Stereo Tracks SBP ICON & C|24 0 02-07-2008 11:53 AM
linking either dynamics or plugins across channels protourman VENUE Live Sound Systems 1 05-30-2007 11:09 PM
LINKING TRACKS FOR STEREO LEVON Pro Tools TDM Systems (Win) 6 08-31-2002 09:01 AM
