Old 04-26-2008, 12:32 PM
Kenny Gioia Kenny Gioia is offline
Default Re: How to turn all Event Markers into Warp Markers ???
Dont credit me for it - I found it either in the 741 read me or under leopard compatibility. The info came from Digidesign. Nevertheless - a very valuable piece of information
That's actually kind of bizarre.
If Digi thought we'd want that feature, shouldn't they have just made a "Turn Events into Warp Markers" menu item?
Old 04-26-2008, 02:11 PM
25ghosts 25ghosts is offline
I definitely agree with you there, Kenny.
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 04-26-2008, 02:21 PM
fman fman is offline
Yep .. thats what i was scouring the manual for - the most obvious solution. I didn't find any of those other solutions in my travels either.
thanks for the help.
fman
Old 04-26-2008, 02:25 PM
T-Low T-Low is offline
+1 for
Old 04-30-2008, 04:03 PM
Mark Dann Mark Dann is offline
It's a no-brainer
  #16
Old 04-29-2011, 01:46 PM
dodlum dodlum is offline
Originally Posted by 25ghosts View Post
And after that select the region in warp mode and right click it and choose "Remove Warp" the warp markers will stay - but the warp is gone....
Does this actually work - I've been trying that here and it doesn't seem to.
I have a part and have been looking at where things go when quantized by 1% and then removing warp. It seems like that process causes the audio to move once with the quantize and once again with the remove warp, but the second doesn't action doesn't move it to where it came from. In some instances (on the same track) it moves certain warp markers closer to where the analysis markers was, and in others further.
It would, as was mentioned here, be ideal for there to be a create warp maker from analysis marker function (with a key command, while you're at it )
Anyone manage to get this to work as you'd figure it should?
Just to say I've tried this on many sources.
David
Cut at warp markers, is this possible chaeffersa Tips & Tricks 3 12-20-2013 07:00 AM
Can you 'Spot' warp markers? TheJamsh Pro Tools 10 0 06-09-2012 11:05 AM
next step after warp markers anth Pro Tools 10 1 04-27-2012 10:10 PM
All Event markers to warp markers? audioluche Pro Tools TDM Systems (Mac) 9 01-11-2010 06:02 AM
PT8 Warp markers converted 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-07-2009 03:40 AM
