Old 12-06-2009, 10:09 AM
ThunderKyss ThunderKyss is offline
Default MBox 2 Pro Control Panel
Is there a control panel for the MBox, when you're using the ASIO driver? For when you're using it with another DAW?
I normally use the SPDIF input for recording, & I can't see it in Samplitude. When I click ASIO panel from inside Samplitude.... I get nothing.
Power PC G5 2GB DDR2 150GB
OSX 10.5.8
Pro Tools 8.0.1 LE Ignition Pack 2
MBox 2 Pro
Old 12-06-2009, 06:48 PM
Default Re: MBox 2 Pro Control Panel
Is this the wrong forum?
OSX 10.5.8
MBox 2 Pro
Old 12-06-2009, 07:03 PM
Ry-Fi Ry-Fi is offline
There IS a control panel, under Win XP at least. It lets you select the clock source and the buffer size. It also shows the driver & firmware version info. And that's pretty much it.
Old 12-07-2009, 09:43 AM
Thank you.
Nothing for Vista?
OSX 10.5.8
MBox 2 Pro
Old 12-07-2009, 02:18 PM
I have no idea, but I'd assume so! Instead of expecting it to launch through your app, can you access it directly? It would be in your Windows Control Panel, called "Digidesign Mbox 2 Pro". If it's not there, I really think your install might be messed up and you should try downloading and installing the standalone drivers (again)...
Old 12-08-2009, 10:17 AM
It was there, thanks
OSX 10.5.8
MBox 2 Pro
Is there a way to put a shortcut to the MBox control panel? richpjr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-23-2012 07:07 AM
Mbox 3 Control Panel Confusion guitar1965 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-22-2011 10:30 AM
Purpose of new MBox Control Panel? Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-08-2011 06:24 PM
Mbox Pro control panel crash mizieg macOS 8 08-05-2011 06:01 AM
MBox 2 Pro Control Panel t.wolfen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-08-2007 07:30 AM
