Pitch doctor.
How can you move an entire signal on a track, to move back, say 89ms. Im experiencing lag on auto tuning vocals. So im gonna try that hopefully. Any suggestions |
Re: Pitch doctor.
set the nudge to 89ms, triple click to select the entire track, press the minus key.
Re: Pitch doctor.
Well, if you've done the 6.4 upgrade, turn on the delay compensation and set the playback engine to use the long delay compensation. It's that simple.
Pitch Doctor has about 3984 samples of latency (CMD click on the volume display and it'll tell you how many samples). I can finally use PD on mixes without having to nudge audio around. That can be a real problem when you send a session file to somebody else and they don't read the track comments about what's been nudged. Love Delay compensation. |
Re: Pitch doctor.
cheers for that. i'll give that a go. one last thing, where do i find the nudge thing to allow me to do this. cheers, RA
Re: Pitch doctor.
The nudge value is located between the top of the edit window and the location window in the little black bar that lets you show inserts, select command focus for the edit window, set your grid, and finally your nudge(OS X). I recommend reading pages 253-4 of your manual to learn what the m and / keys can do when nudging.
Mark Reis Sound Designer |
Re: Pitch doctor.
Re: Pitch doctor.
It's still better than nudging or using TimeAdjuster on every track. Hopefully they'll perfect the implementation in the months to come... Cheers |
Pitch Doctor question | studioboy | Pro Tools TDM Systems (Mac) | 2 | 01-24-2005 10:16 AM |
Pitch Doctor - No version for LE | HughM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-17-2005 11:28 PM |
Help with WM Pitch Doctor | Mack McLaughlin | Pro Tools TDM Systems (Mac) | 3 | 04-09-2003 05:43 PM |
Pitch Doctor Problem-Help! | Armando | Pro Tools TDM Systems (Mac) | 2 | 08-03-2002 02:58 PM |
pitch doctor | Dr. J | Pro Tools TDM Systems (Mac) | 0 | 01-18-2002 06:41 PM |
