Re: Sample Rate for professionals
24/48k for everything I do also, which is mostly classical symphonies and operas and jazz recorded live in less than stellar rooms.
The noise that I get from the HVAC and mediocre acoustics would more than defeat any hypothetical or theoretical improvement in sound quality by moving to 96k and eat up twice as much hard drive space. Also, I don't record at 96k because the consoles that I record from, only operate at 44.1k or 48k.
Justice C. Bigler www.justicebigler.com Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB 2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre Road/hotel: Roland OctaCaputre / Apogee One |
48KHz, because we do film and TV and that's the standard. For records, 96KHz.
"Best" sample rate... yeah, that's a conversation that never goes well. It's a topic that drenched online forums 5-10 years ago. These days, convertors are so good (and CDs are so rare, so it's about Apple Music and streaming) that even 44.1 competes with higher rates. I just don't hear people talk about it much anymore, so don't worry too much about the math. |
Ah, thanks,
Eric, do I understand you right, if you told: 48kHz for film and TV sounds, 96kHz for "only music"? I am only interested in songs without TV or film.
Pro Tools 12.5.1 Win 10 Eleven Rack Asio4All M-Audio Oxygen 49 mk4 TLM 102 Gibson Classic Rock Marble AKG K 271 MKII |
For CD 44.1 is the standard, exact HiRes should be 88.2
For Video 48 is the standard, exact HiRes should be 96 For high end classical music or similiar, 176.4 or DSD/DXD The ADAT ran at 48 KHz because was based on a video device, S-VHS, the same applies for most of the digital audio consoles since they can be used for video as well. On my experience, there's no audible difference between 44.1 and 48 but I stick to 44.1 when doing normal recordings and use 48 only if video is related to it, also I do prefer to use exact numbers when going to higher sample rates because when doing the sample rate conversion to something lower, it make it simpler and more precise.
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
Words of wisdom. 44.1 for me.
#16
24/48 for me. When necessary, I zap the HVAC with noise reduction plugs.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
#17
If the end product is going to be 44.1 then is there any wisdom in working to 88.2kHz rather than 96kHz?
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12 |
#18
NO !!!!
#19
48 if there's a reasonable chance it will wind up in a video or film. 96 if it's purist classical or jazz that will receive little or no EQ. 44.1 for everything else.
99.9% of records would come out sounding identical regardless of sample rate, due to all the mangling and dynamic torture they go through. Seriously, you're going to add 9 dB at 1.5 kHz with some digital EQ plugin, and you're worried about the phase shift of your converters?
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#20
At Capitol Records, Al Schmitt uses 24/96 for recording and 24/192 for mixing. He did tell me he's starting to record everything in 192 now - I didn't argue, but it sounds like overkill to me.
I don't have the resources, so I use 24/96 for recording and mixing. Last edited by chrismeraz; 12-06-2017 at 12:27 AM. |
Hopefully an easy one for you guys: Opening 8 KHz sample rate / 16 bit sample size | sample | Pro Tools 11 | 2 | 02-24-2016 01:04 PM |
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up | finalcut | Windows | 12 | 02-20-2012 04:00 AM |
Bit Rate / Sample rate | supersam83 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-25-2010 08:55 PM |
MBox Micro Sample Max Sample Rate Only 48 kHz? | Joe Sciacca | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-07-2008 12:52 PM |
Bit Rate/Sample Rate problem? The chipmunks? | bspro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-17-2008 05:40 PM |
