Old 10-30-2017, 06:54 PM
ripekeai ripekeai is offline
Default Top|Back not closing plugin like Eucon 3.6
A common workflow for me would be, press EQ on the S3, make some adjustments, and then press Top|Back to close the EQ. Since updating to 3.7, this no longer works as the menu returns to the top on the S3 but the EQ remains open. Is this an intentional update? Can we get the prior functionality back?
OSX 10.12.6
PTHD 12.8.2r2
Eucon 3.7
Avid S3+Dock
Old 10-30-2017, 08:36 PM
mattrixx mattrixx is offline
Default Re: Top|Back not closing plugin like Eucon 3.6
That is working as it should here on 3.7
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 10-31-2017, 06:29 PM
EddieJones's Avatar
Can you check the General tab in EuControl and make sure the Close Plugins when editing is checked. If it is toggle it anyway to make sure.
Old 11-01-2017, 06:09 AM
Impervious Impervious is offline
I had the same issue and what works is toggling like Eddie said. I only had to do it once, so it’s not like every time you shut the computer down you’ll have to do it. It worked for me and I hope it works for you. Let us know if it does!
Old 11-01-2017, 02:23 PM
Although I never deliberately unchecked, it was in need of a check. Didn't realize that was an option so thank you for the resolution.
Old 11-03-2017, 05:43 AM
I’m glad you got it sorted out
Pro Tools hangs when closing plugin window George2000 Windows 6 09-12-2017 03:26 PM
Plugin written automation is gone after closing protools sabinacovarrubias Pro Tools 12 1 06-29-2017 12:42 PM
Top/Back button not closing plugin? Tim R. Avid S1, S3, Dock and Control App 5 02-12-2016 08:26 PM
PT 11 Crashes While Playback When Closing Plugin Windows SpaghettySaussage macOS 0 10-26-2014 09:46 PM
Key command for closing plugin windows? IO Composer Pro Tools TDM Systems (Mac) 9 08-10-2009 04:38 AM
