Old 06-09-2003, 01:57 AM
Armando Armando is offline
Default ethernet cable length
I'm moving my G4 MDD into a "machine room". How long can the CAT5 cable be?
Armando
Old 06-09-2003, 11:14 AM
Mario C Mario C is offline
Default Re: ethernet cable length
I don't know real specs, but we're running cat5 anywhere from 50-100 ft between hubs in our facility.
Mario C
Metcom Studios
www.metcomstudios.com
Old 06-09-2003, 03:41 PM
Thanks!
Armando
Old 06-10-2003, 12:22 AM
m a r k m a r k is offline
Unless there is something special about C|24 and cable lengths, keep it under 300 feet and you should be fine...standard ethernet/cat5 spec is 100 meters or about 328 feet. If you don't know how to make a cross-over cable, check this URL :
http://tinyurl.com/7au2
Hope that helps-
m a r k
Cat 5e 350mHz or better ethernet cable? Kristo Kotkas VENUE Live Sound Systems 5 10-02-2013 10:16 AM
DSL phone cable run OR Ethernet cable run stormmusic Post - Surround - Video 9 12-12-2011 09:26 AM
PC ethernet cable length nymo ProControl, Control|24, Command|8 3 01-03-2009 10:15 PM
Where do you connect the Ethernet cable if the DSL Imagine ICON & C|24 1 04-18-2004 11:26 AM
Footswitcing C24 and Ethernet cable fid ICON & C|24 5 09-11-2002 08:16 AM
