Old 08-18-2002, 05:59 PM
fid fid is offline
Default Footswitcing C24 and Ethernet cable
When using the Digi supplied ethernet cable I have full control of protools. However I need a longer cable than is supplied because my noisy gear is in another room other than my control room. So I am using a Cat 5 crossover cable which is 3o feet. The problem is I can't get the footswitching to work. It works perfectly well with the supplied cable. Is is because the cable is shielded and the connectors are metal? Could this be a grounding issue. No one at Digi can help me. Can anybody out there help.
Fid
Old 08-19-2002, 08:44 AM
Jan Folkson Jan Folkson is offline
Default Re: Footswitcing C24 and Ethernet cable
Tha's pretty wacky. AFAIK the footswitch is mechanical and should just send a message to the C/24, which then sends a message via ethernet. Meanind that the switch itself doesn't send directly over ethernet. For example if you set the fs1 to enable recording. The swich should be doing the same thing as pressing the record button on the C/24 itself.
- Jan Folkson
www.janfolkson.com
Old 08-19-2002, 11:12 AM
R SCHLESINGER R SCHLESINGER is offline
FID
YES!!!!!!
I can help you!
e-mail or call me w/ the details
I have been doing the recording studio thing for 18 yrs
I am known for my wiring
there is a good chance your CAT 5 cable or that your footswitch cable is wired wrong
then again, if you use cable that is utter garbage, that could be a reason too
[email protected]
(818) 508-1070
RADAR
Old 09-10-2002, 04:25 PM
ekuehnl's Avatar
ekuehnl ekuehnl is offline
ACI/ALP Moderator
That's the biggest load of B.S. I've heard in a while. Shouldn't you be advertising your services on DigiProNet instead of in these forums? They are clearly labeled "No Commercial Posts!"
Old 09-11-2002, 12:03 AM
UPON FURTHER INVESTIGATION
AND IN RESPONSE TO YOUR PHONE CALL
THE CAT5 CABLE FOR THE C24 HAS A CUSTOM CONFIGURATION. A NORMAL CAT5 CABLE OR A CAT5 CROSSOVER CABLE WILL NOT WORK
ANY AND ALL PARTS TO MAKE A CUSTOM CABLE ARE READILY AVAILABLE.
RADAR
ps fid, is there something wrong w/ your e mail server?
Old 09-11-2002, 08:16 AM
the time it takes me to go to the store and pick up cable that i normally do not use, travel 1hr away(thats in 1 direction) to pick up 2 connectors, and then fedex someone a cable, is not a way to run a business. i am doing it because i am a nice guy.
there is no way that i can charge the amount of time it takes to put together this cable.
however, by helping fid, there are a couple of other people that i can help out in the future.
digi is aware of the previous post. they are the ones who told me where they get their cables from.
i make my money in the pro studio scene, w/ major studio installs and consulting! i dont make it by trying to help ppl out online.
Cat 5e 350mHz or better ethernet cable? Kristo Kotkas VENUE Live Sound Systems 5 10-02-2013 10:16 AM
DSL phone cable run OR Ethernet cable run stormmusic Post - Surround - Video 9 12-12-2011 09:26 AM
PC ethernet cable length nymo ProControl, Control|24, Command|8 3 01-03-2009 10:15 PM
Where do you connect the Ethernet cable if the DSL Imagine ICON & C|24 1 04-18-2004 11:26 AM
ethernet cable length Armando ICON & C|24 3 06-10-2003 12:22 AM
