Old 01-22-2019, 08:45 AM
helenvee helenvee is offline
Default UVI Workstation in Pro Tools 2018, window not big enough
I just downloaded the free UVI Workstation and loaded it as a plugin in PT. When I open it in standalone mode and load an instrument, along the bottom of the window there are some controls such as saturation, reverb, etc. However, when I open it as a plugin in PT, the window is smaller and I can see the very tops of those buttons but the edge of the window cuts them off and I can't fully see them or use them. PT won't let me resize the window. Any one else having this problem? How to fix?
I'm running UVI Workstation v3.0.5, PT 2018.7 on a PC.
Old 02-21-2019, 02:45 PM
Default Re: UVI Workstation in Pro Tools 2018, window not big enough
bump
Old 02-21-2019, 03:18 PM
ChuckS ChuckS is offline
What version of Windows? Are you scaling the the Windows UI to a percentage other than 100 or 200%?
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 02-28-2019, 12:23 PM
Aha! I'm on Windows 10 Pro. My UI was scaled to 125%, I changed it to 100%, and it looks correct now. Thank you!
Old 02-28-2019, 02:06 PM
If you need to change the resolution of your display, it seems to work best if you use your video card driver to set the resolution rather than Windows scaling. So using Intel graphics as an example, if you right-click the desktop there's usually an option for Intel Graphics Settings. There you can set the display resolution to what you like. I have a 4k display on my laptop that I set the resolution in the Intel control panel to HD (1920 x 1080) and everything works flawlessly.
PT 2018.12.0. "Open Plug-ins on Workstation When Editing" broken? karegranat Avid S4/S6 14 04-15-2019 05:15 PM
how to install 2018 7 on Window 7 kw88keys Windows 12 08-27-2018 03:00 PM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
2018.3 Edit window bug Bustback Pro Tools 2018 6 04-09-2018 03:11 AM
Edit window zoom SLOW 2018.3 khoop2112 Pro Tools 2018 6 03-10-2018 03:34 PM
