#21
Re: Video Card - Mac Pro High Sierra & Native
I recommend sticking to the list of compatible Metal capable GPUs in Apple's latest support article.
I recently replace my AMD 5770 in my Mac Pro with a Sapphire RX 580. It worked perfectly without any drivers in High Sierra. Note that before upgrading, you will need to get an additional PCIE power cable as these GPUs require two of them. Also, if you're running an older Apple Cinema display, you'll need a mini Display Port to regular Display Port adapter. https://support.apple.com/en-us/HT208898 |
#22
I may try the MSI RX-560 to replace my HD5770
#23
I did exactly that. Works great.
http://www.merlinsound.de |
#24
Cool deal. I only get CPU(-9093) spikes when I open a Waves plugin to make changes. No spikes/errors if the plugin windows is closed. (64 buffer) |
#25
This site should help everyone one what is compatible with Apples most successful Mac Pro:
https://everymac.com/systems/apple/m...splayport.html
-Mac Pro 7,1 16core 3.2GHz 96GB -OSX 12.7.2 -PTHDN 2023.12 Ultimate -HD Omni -BM Intensity Pro -Waves Mercury+SSL4000 Collection+Abbey Roads -iZotope RX10 Advanced -iZotope Post Production Suite 6 -iZotope Music Production Suite 5 -HALO UP/DOWN MIX -ANYMIX -Delonghi Perfecta ESAM 5600.S |
#26
That said, it's blinking much less often now than it did at first.
-- Michael PT Ultimate Native 2021.10 Mac Pro 7,1 16-core, 288G RAM OS 11.6.1 Big Sur |
#27
Not getting blinks here.
Double check (Move) the Mac PC switch possibly. I use with three (1080-4K-1080) (DVI=DVI, mdp to dp, mdp active to DVI) MacOs 10.14 seemed to better it's performance.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
#28
Installed the MSI RX560 Aero 4g.
Works well and improved my Protools cpu spikes/errors that I was having with plugins GUIs at 64buffer. On startup, the apple boot screen only displays for about 2 sec then it goes to the login screen. Other than that, everything works. OS10.13.6 |
#29
Did you get this sorted?
I can't handle beat detective being this unresponsive. See signature for system specs.
James Welch Recording Engineer | Producer Masterlink Productions Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire) macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24 |
#30
Having upgraded the Mac Pro 5,1 CPU from Quad-Core 2.4GHz to Six-Core 3.46GHz and the graphics card from from the Radeon 5770 to an AMD Radeon R9 280X with 3GB or VRAM, the difference is marked. I have attached a screenshot of a big session and you'll see the load on CPU and HDX. This was able to play on loop without any errors.
The pain with upgrading the graphics card is of course powering it alongside the HDX card, however if you're handy with a soldering iron you can splice the HDX power connector into the graphics card power cable so the graphics card is still getting it's juice from both PCI Aux Power Sockets. I've heard the HDX only needs power for the fan so is not a huge draw. I have more tests to do so will report back.
MAC PRO High Sierra & PTHD 2018 can't recognized PCIe Native card | Sutee Sangsareechon | Pro Tools 2018 | 1 | 05-11-2019 04:48 PM |
S6L AVB with OS X High Sierra | brinnbacka | VENUE Live Sound Systems | 3 | 10-20-2018 12:52 AM |
Question: Sierra or High Sierra for PTHD 2018.3? | johnnyv | Pro Tools 2018 | 25 | 03-18-2018 08:30 PM |
High Sample rates with Native HD card | Media Man | Windows | 6 | 02-27-2017 11:48 AM |
HD Native card physically generates high pitch whine or squeal | mlange | Pro Tools HDX & HD Native Systems (Win) | 6 | 03-15-2012 02:59 AM |
