#5761
Re: i7 Builds - Specs and Results
Since I was in a rush, I used a lot of my old PC parts. I went with the intel i7 4770k cpu, Gigabyte GA-Z87X-UD3H MB, ASUS 210 Video Card, as well as 16 gigs of 1600 Gskill RAM. I wanted Corsair, but there was none available, so I went with what was available. I also wanted the UD5H, but it was not available either, so I went with the 3H. I also went with a 600W corsair semi modular PSU.
I also went with the Fractal R4 case. It's pretty big, but also super quiet. After using this machine, I am going to update the RAM to 32 gigs, and put in a Quadro Video card as I am doing quite a bit of video work as well these days.
Sign up for all things....AWESOME! Kris May the music move you |
#5762
Believe it or not, I still have not touched any BIOS settings other than the RAM timings, and for the first two days, I didn't optimize Windows either!!! This machine is a beast!
#5763
Once you install that Quadro card, are you sure 600 W is enough to power everything under load?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#5764
No, I don't, but I will pick up another PSU when the I get the quadro card. I will move up to 750W. Again, this was an emergency build, and I could not be happier with the results.
#5765
How about this for a start? 'GIGABYTE GA-X79-UP4 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard'. My i7 has bit the dust! What are the thoughts of an lga 2011, as compared to the lga 1150?
Thanks,,,,, Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
#5766
2011 socket is quit a bit more powerful than the 1150. At least 30% or more. It's not going to have the newest technology on it though as it's a generation behind.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#5767
Thanks again! Mike
#5768
#5769
Also most socket 2011 boards also can run xeon E5-2600 processors. If you have the money those have up to 12-cores. Same procs they're using in the new Mac Pro I do believe. So yes socket 2011 for max potential power. But most any modern 1150 or 2011 based rig should be pretty impressive.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
#5770
Thanks guys, I had read somewhere about SSD's not always up to par, (for the price). Thanks albee1952, I'll check that Samsung out. In the few days of research, I have noticed the 6 core is priced a lot higher (percentage wise, for what you get), than the SSD's?! Does PT's utilize those 2 extra cores (6 core), enough to validate their cost, and with the same idea, does the SSD speed things up enough to justify their cost? As for the ram, the board I mentioned above, with 8 slots, will give me the opportunity to start with 4 x 4's for now, and then a little later, another set of 4. Although ram is still so cheap, depending on SSD and or 6 core choice, it might be best to go ahead with all 32 right off the get go?!
Thanks guys,, always great info, Mike
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
