  #61
Old 08-16-2014, 09:04 AM
Herbieoz Herbieoz is offline
Default Re: Done.
Hi all. Just popped in to see whether anything has changed. Nope. I feel for you all who have wasted money. Keep track of your dollars spent, length of time software not working (3 years not properly supported now), and negative impact on income. Collect evidence, not just emotion. Avid continue to sell something knowing that it does not work (even Dealers are advising other alternatives - a long-term key Avid distributor recently showed about 40 of their top customers the new Behringer solutions rather than the S5 and S6 for god's sake - even they know the Avid stuff is crap).
  #62
Old 09-10-2014, 01:57 PM
mesaone mesaone is offline
Default
Well, I'm planning to get a second Artist Mix.
My current setup is Mix > Router > PC.. Using ethernet cables (the supplied crossover cable is between the Mix and router)
When I get the second Mix, is it advisable to do Mix (x2) > switch > Router > PC, or do I even need the switch? Which would be more stable?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
  #63
Old 09-10-2014, 02:17 PM
Manu101 Manu101 is offline
Default Re: Done.
I have 2 Mix and 1 Transport connected to an "unmanaged" switch that is connected to my computer in it's own ethernet port (no internet on this path). Never had any problem.
Manu
PT Ultimate - Mac Studio M1 Max - Monterey - RME Fireface UFX II - 2x S1, 1x Dock with an iPad 7th gen - Genelec 8330 5.1 setup
  #64
Old 09-10-2014, 03:04 PM
Default
Unfortunately, I have to keep my DAW online, and the PC only has one ethernet port. So I would have to connect to the router one way or the other.
Would that pose a problem?
I could have my router, controllers, and computer all plug into a switch I suppose.
  #65
Old 09-10-2014, 03:11 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Done.
I was planing on buying an airport card or similar device to allow me to catch a wifi signal if I needed to connect. B/c that way I could use my 1 Ethernet port exclusively for the artist (ie static ip as well)
Turns out when ever I want to be online I can use my phone as a modem..... 4GLTE speeds are not bad at all. I don't live online but if I need to update a plug or two it's easier than installing a card
Daniel
