  #31
Old 12-12-2013, 01:53 PM
Craig F Craig F is offline
Default Re: Proper Recording Levels
Originally Posted by bryced87 View Post
So basically if my recording levels aren't clipping I'm fine?
Maybe, maybe not. Depends on inter sample clipping.
friend of mine from Berklee Music says that dBFS is what you always go by
that's a loaded statement of miss information
dBFS: decibels Full Scale, 0 is top and other number is the headroom to 0
dBu, dBm, dBV are sales the are relative to a nominal voltage into a load
So a mic pre that has a measurement of 0VU = +4dBu with 22dB of head room means it would clip at 22VU or +26dBu so for digital it would be -22dBFS
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
  #32
Old 12-12-2013, 01:58 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
It's all about headroom. Green is good, yellow (or orange) is caution and red means stop. It's like a traffic signal. It's taken me almost 10 years to figure this out. The input meters on my console match the ones in ProTools so the top segment of green and bottom segment of yellow correspond by default.
This is not to say you can't record hotter but the system sounds best when you operate within the green peaking into yellow. If your mixes are too quiet (or quieter than you are used to) you can always make the files louder outside of ProTools. Technically that is mastering.
When I mix for broadcast (USA ATSC A/85) I have to put a hard cap at -10 then use a loudness meter (TC LM2) to adjust perceived loudness to operate within the standard. This generally corresponds to green peaking into yellow on the PT meters (keep in mind dynamic range is reduced by limiting and squeezing pretty good).
I will choose,
Freewill
http://jimdiazaudio.com/
  #33
Old 12-12-2013, 08:11 PM
bryced87 bryced87 is offline
Maybe I'm still lost because -22dBFS sounds super quiet to me. Which side of the fader am I looking at. There are numbers on both sides.
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
  #34
Old 12-12-2013, 08:23 PM
YYR123's Avatar
YYR123 YYR123 is offline
The Dbfs side of the fader the other side is another scale - if it's sounds quite turn up your monitoring amps
Daniel
  #35
Old 12-12-2013, 08:24 PM
but which side is the Dbfs site of the meter?
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
  #36
Old 12-12-2013, 08:50 PM
YYR123's Avatar
I could be wrong (don't think so) Dbfs on the right and the left is the attenuation or (possibly) rms scale (don't know if that's right)
Go chargers !
Daniel
  #37
Old 12-12-2013, 09:18 PM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Go chargers !
He'll yeah🏈
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey
Alesis Masterlink, Alesis Adat LX20,
, Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon,
Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric.
http://www.johnackermusic.com/
protools@verizon.net
Live and Let Live
  #38
Old 12-12-2013, 09:19 PM
Looking at the Meters now it looks like I should try to aim for -12. It is okay if the meter is sometimes in the yellow when I record? Sometimes if I'm recording bass there are softer parts and then louder ones.
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
  #39
Old 12-12-2013, 09:35 PM
That's where you might want to use a little compression to even it out a little, if that's what you want.
Live and Let Live
  #40
Old 12-12-2013, 09:39 PM
YYR123's Avatar
As stated b/F - feli said read and read some more
I shoot for peak -8 personally -
Softer and louder parts ? Enter the compressor !!!!
Daniel
Question on proper levels LongRoad Tips & Tricks 12 06-14-2009 04:56 AM
rca recording levels/proper interface channel rygar22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-07-2005 01:21 AM
Recording Levels jawjam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 08-20-2004 02:32 AM
Proper recording/monitoring of vocals MarkH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 26 08-17-2004 12:15 AM
*Recording Levels* mentalmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-03-2002 10:10 AM
