Old 08-26-2004, 07:59 AM
Badooker Badooker is offline
Default extra time at the end of your song
Ok... I let the metronome go for a while so I could play and practice with a click at the end of a song... now how do I get rid of all the extra minutes and have the end of the track only a few seconds after the end of the waves?
b
Old 08-26-2004, 09:02 AM
Slim Shady Slim Shady is offline
Default Re: extra time at the end of your song
why does it matter? it's just empty space right?
Old 08-26-2004, 10:29 AM
St Mix St Mix is offline
I get the same thing too. I found out that somehow extra volume edit points get put way down the line (like 20 minutes after the song is done). I have to find them all and delete them. It makes bouncing to disk a pain, cause you'll have 20 minutes of dead air at the end of the bounce (if you don't select the area of the song you want to bounce first).
Old 08-26-2004, 11:29 AM
JohnT JohnT is offline
When bouncing set you in and out to the desired time. You won't get all that extra time caused by automation. You can also select from the desired end of the track to the "real" end of the track with CTRL - SHIFT - RETURN while viewing the automation track in EDIT. Then delete it. That will get rid of any automation points.
Mpowered PT w/ProjectMix with Black Lion mods, and Transit, Macbook Pro, Reason, Live, Axiom 25, Keystation 88, Coffee with cream, no sugar
Old 08-26-2004, 12:23 PM
Bezo Bezo is offline
I feel your pain. That happens to me when working with MIDI. Sometimes I'll cut of the end of a recording, but Pro Tools treats the tracks as if data is still there. I'd like to get rid of the dead space because hitting apple+zoom includes the unused track space. Same problem with double clicking a track to select it.
Anyone know how to get Pro Tools to recognize that the data/waves are gone?
PTLE 8.0.5, Digi 002 Rack
iMac 3.06Hz Intel Core 2 Duo w/8GB RAM, OS 10.6.8
Glyph GT050Q Drives
Old 08-26-2004, 03:04 PM
My mistake on highlighting to the end of the song's data. OPTION-SHIFT-RETURN. Do that from a position just after your song on all tracks while viewing automation data envelopes and delete.
Old 08-30-2004, 11:59 AM
the larger issue here is how these control points are added in the first place. they can be as far as 10 minutes or so down the road.
Using different time signatures within the same song David Penick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-12-2009 07:43 PM
cutting time out of song Ziko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-14-2006 02:47 AM
creating extra time at intro of track wedgewedge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-23-2005 03:08 PM
How do I get rid of extra time at the end of my song Zen685 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-02-2003 09:30 PM
deleting extra time at end of session anders Tips & Tricks 3 04-10-2000 09:39 AM
