Old 10-09-2012, 02:40 AM
simon hunt simon hunt is offline
Default 2 monitors back to 1 - can't get video back from right screen
Hi guys,
A simple one, I guess, but can't find the answer.
Was working on PT with dual monitors.
Dragged video to the right screen.
Now back on single screen. Video is nowhere to be seen, presumably it's off to the right.
Deleting the video and its track does nothing, it just won't appear ....
Any suggestions ?
thanks
Simon
simon
Old 10-09-2012, 06:41 AM
Brandonx1 Brandonx1 is offline
Default Re: 2 monitors back to 1 - can't get video back from right screen
I think the window positions are a dae pref or something. I would download the Digidesign pref trashed app from this forum and trash all the digi, dae, and avid prefs. See where that gets you.
Old 10-09-2012, 08:25 AM
Lincoln Mitchell Lincoln Mitchell is offline
Jave you tried re starting?
Lincoln Mitchell
Pro Tools | latest
Mac Mini Server | OSX | Current
16GB Ram | SSHD
Apogee Ensemble Thunderbolt
Old 10-09-2012, 08:45 AM
spidey01 spidey01 is offline
Reconnect te other monitor drag the video back to its original position or to the view of the monitor you are going to keep, save session, turn off computer remove monitor and startup again this should work
Old 10-09-2012, 11:00 AM
Richard901 Richard901 is offline
If you only have access to one monitor, these should help:
http://forums.macrumors.com/showthread.php?t=359732
http://www.jonathanlaliberte.com/200...r-main-screen/
Pro Tools 2023.9
Ventura 13.6
Old 10-09-2012, 05:37 PM
Tweakhead Tweakhead is offline
Hi Simon - A quick fix can be to do a live disconnect on the monitor and wait 5-10 seconds then, when you plug it back in, the offscreen floating windows should all have defaulted back to the main monitor screen.
Then once you have configured how you like your window sizes and positions with your single monitor, save a Window Configuration in a "Window Config Import Session" and then import just that Window Config into any future sessions that exhibit the same problem.
Should I back back all files from my internal hd to my OWC external firewire800 hd? moya83 macOS 1 11-12-2012 06:36 AM
Video Play back monitors question T_S_Harris Post - Surround - Video 1 11-25-2011 09:25 AM
Studio Monitors not playing any music back delgado 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-22-2010 06:46 PM
Screen freezes for a moment, then comes back... Eric Klinger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 46 02-15-2007 03:20 PM
Digital feed back on play back after Bounce drew88 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-12-2005 01:18 PM
