QUESTION ABOUT INSERTING MIDI PLUG INS
Hi, Kind of new at pro tools. Im running 6.7 on an mbox, and I want to record my native instruments elektrik piano plug in on a track. When Im recording midi data it does not allow me to use an insert. How am I able to get midi into my elektrik piano plug in and record midi data at the same time? I have no idea. Any help would be great! -Pete
Re: QUESTION ABOUT INSERTING MIDI PLUG INS
Watch the DiskFlix tutorial about sampletank. The process is pretty similar, just replace 'elektric piano' everywhere they say 'sampletank'.
Let us know if you need more help after that.
I try to do it but next to elektrk piano on the midi out it says no channels activated. Im at a loss
its still not working. i dunno
Did you load a sound into the Elektric Piano?
Did you record arm the MIDI track?
Yes there is a sound in the elektric piano and i record arm the midi track. Midi gets to the stand alone elektric piano but not when it is used as a pro tools plug in
OK, how about a little test?
Create a new session. Create a stereo aux track, make sure it's fader turned up and insert the Elektric Piano on it. Click File on the EP and select the MK-1 essential patch. Create a MIDI track. Set it's input to the port that your keyboard controller is on, and set the output to "Elektrik Piano 1 - (No Channels Activated)". Record arm the MIDI track. Does the meter on the MIDI track show that input is being received? If so, do you hear sound from the EP?
lol. thanks for your time. ill try it right now
inserting rtas plug ins on a track | N0TiQ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-31-2008 04:09 AM |
Inserting EQ plug doesn't default to the EQ panel | mtung | ICON & C|24 | 3 | 04-20-2007 01:24 PM |
Inserting A Plug-In | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-25-2005 09:36 PM |
HD stops playing while inserting plug in | poncival | Pro Tools TDM Systems (Mac) | 1 | 09-14-2004 06:05 AM |
inserting a plug in on an input while overdubbing | music project | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-07-2004 09:10 AM |
