Old 08-19-2017, 08:33 AM
GeorgeA GeorgeA is offline
Default Bug? "Save A Copy In" not working properly
I edit a daily radio program and we use "Save A Copy In" extensively to move files between Pro Tools 12 and Pro Tools 8.
Each folder has 12 sessions. We have a 'parent' folder that contains the 12 sessions, an Audio Files folder that contains the audio 'unique to that set of programs. Another Audio Files folder one level up that contains all the music and intro's for the whole year (so we are not duplicating the same audio files over and over.
I normally edit the programs in PT12 and "Save A Copy In" to send them to the producer to write intro's and outtro's (he uses PT8). We have been doing this for over 10 years with no problem. Until yesterday.
Yesterday after editing and saving 3 other programs with no issue, all of a sudden "Save A Copy In" is not creating a new folder and duplicating all the audio files.
The way it would normally work, you would have to click "Files," then "Save A Copy In," then "Session (Pro Tools 7-9)" and select under ITEMS to COPY check the box next to "Audio Files." THEN it would copy all the audio files, session, fades, etc. into a separate folder. NOW, regardless whether that box is checked or not, it copies all the audio files into a separate folder.
HELP! What is going on, is this a bug in Pro Tools 12.8?
Thanks,
George
Old 08-19-2017, 08:09 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Re: Bug? "Save A Copy In" not working properly
Hey George,
First things first,is that we need to know your system details. Also whatever troubleshooting you've done. There are users that may have the same caliber of system and can test to see if it can can reproduced. Technically it's not a bug, unless it's been re-created on multiple systems and OS' repeatedly.
I would start by deleting your prefs, ect as outlined in the READ THIS BEFORE POSTING.
CHeers...we'll get you sorted out
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 08-20-2017, 09:55 AM
ronwasserman's Avatar
ronwasserman ronwasserman is offline
Trash preferences....start over.
Ron Wasserman
http://www.ronw.com
http://www.imdb.me/ronwasserman
http://www.fishertheband.com
Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version.
Old 08-20-2017, 04:08 PM
Gentlemen,
Thank you for your kind response. As you can tell, I rarely post here.
Let me say that this appears to be working INTERMITTENTLY. The original session that I had the problem with is saving fine. A few other sessions are not saving correctly.
One thing I did notice, when you first click File and "Save a Copy In", the window that pops up has an option halfway down on the left side called "Items To Copy" and under that is a check box with "Audio Files" next to it. That check box is not checked by default (nor the box below it).
From the drop down menu at the top, select "Session (Pro Tools 7->9). If it is NOT going to save correctly you will notice that under "Items To Copy" the the entire line that says "Audio Files" will be grayed out (including the check box) BUT if you look closely the box will be checked. And the line below it will be grayed out but that box checked also. (Line reads Convert to Specified Format).
Still not sure what is causing it to work that way, but seems like a bug to me! Thanks for the help.
George
As for my system:
Operating System
Windows System : Microsoft Windows 10 Professional 10.00.14393
Platform Compliance : x64
Computer
Mainboard : ASUS M4A88TD-V EVO/USB3
BIOS : AMI (OEM) 1601 09/08/2010
Total Memory : 8GB DIMM DDR3
Processors
Processor : AMD Phenom(tm) II X6 1090T Processor (6C 3.62GHz, 2GHz IMC, 6x 512kB L2, 6x 6MB L3)
Socket/Slot : AM2r2/AM3
Chipset
Memory Controller : ASUS M5A88-V EVO 2x 2GHz (4GHz)
Memory Controller : AMD F10 Athlon 64/Opteron/Sempron HT Hub 2x 2GHz (4GHz), 2x 4GB DIMM DDR3 1.34GHz 128-bit
Memory Module(s)
Memory Module : G.Skill F3-10666CL9-4GBRL 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : ACI VW246
(1920x1080, 24.0")
Monitor/Panel : SAMSUNG
(1600x1200, 7.2")
Video Adapter : NVIDIA GeForce GT 730 (2CU 96SP SM5.0 1.4GHz, 32kB L2, 4GB 1.4GHz, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce GT 730 (96SP 2C 1.4GHz, 32kB L2, 4GB 1.4GHz)
Compute Shader Processor : NVIDIA GeForce GT 730 (96SP 2C 1.4GHz, 32kB L2, 4GB 1.4GHz)
OpenGL Processor : GeForce GT 730/PCIe/SSE2 (4GB)
Storage Devices
WDC WD2002FAEX-007BA0 (2TB, SATA600, 3.5", 7200rpm) : 2TB (E:)
WDC WD10EALS-00Z8A0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (D:)
WDC WD1002FAEX-00Y9A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (C:)
PLEXTOR DVDR PX-712A (34.9MB, ATA33, DVD+-RW, CD-RW, 8MB Cache) : 33MB (G:)
ASUS DRW-24B1ST i (SATA150, DVD+-RW, CD-RW, 768kB Cache) : N/A (F:)
Logical Storage Devices
Shire (C:) : 931GB (NTFS, 4kB) @ WDC WD1002FAEX-00Y9A0 (1TB, SATA600, 3.5", 7200rpm)
Gondor (D:) : 932GB (NTFS, 4kB) @ WDC WD10EALS-00Z8A0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
Hard Disk : 450MB (NTFS, 4kB) @ WDC WD1002FAEX-00Y9A0 (1TB, SATA600, 3.5", 7200rpm)
Mordor (E:) : 2TB (NTFS, 4kB) @ 2x WDC WD2002FAEX-007BA0 (2TB, SAS/SATA600, 3.5", 7200rpm)
CD069A8 (G:) : 33MB (CDFS, 2kB, Read-Only) @ PLEXTOR DVDR PX-712A (34.9MB, ATA33, DVD+-RW, CD-RW, 8MB Cache)
Optical Drive (F:) : N/A @ ASUS DRW-24B1ST i (SATA150, DVD+-RW, CD-RW, 768kB Cache)
Peripherals
LPC Hub Controller #1 : AMD IXP SB600/700/800 SMBUS Controller
LPC Hub Controller #2 : ASUS M5A88-V EVO
LPC Legacy Controller #1 : T2 87-21
Audio Device : ASUS M5A88-V EVO
Audio Codec : Realtek Semi High Definition Audio
Audio Codec : 32768 0000
Audio Device : EVGA GF108 High Definition Audio Controller
Audio Codec : nVidia 0014
Serial Port(s) : 1
Disk Controller : ASUS SB700/800 SATA Controller [IDE mode]
Disk Controller : ASUS SB700/800 IDE
Disk Controller : ASUS M5A88-V EVO
USB Controller #1 : ASUS M5A88-V EVO
USB Controller #2 : ASUS M5A88-V EVO
USB Controller #3 : ASUS M5A88-V EVO
USB Controller #4 : ASUS M5A88-V EVO
USB Controller #5 : ASUS M5A88-V EVO
USB Controller #6 : ASUS M5A88-V EVO
USB Controller #7 : ASUS M5A88-V EVO
USB Controller #8 : VIA VL80x xHCI USB 3.0 Controller
FireWire/1394 Controller #1 : ASUS M5A88-V EVO
SMBus/i2c Controller #1 : ATI SB800 SMBus
Network Services
Network Adapter : Realtek PCIe GBE Family Controller #2 (Ethernet, 1Gbps)
Old 09-15-2017, 10:31 AM
Matts Matts is offline
I hope this got solved?
But if not… something to try out.
I've both heard from others and also myself run into this strange thing that "Save Copy In…" behaves correctly, in at least some versions of Pro Tools, only when you run this command the first thing you do after opening Pro Tools.
And I mean really the first thing: just open PT and directly after that open the session (don't start playback, don't do anything!), select "Save Copy In…" from the File menu and tick what needs to be ticked and let it run.
Otherwise Save Copy In… will probably behave erratically.
Try this, and report back, if you can.
-matts
Old 09-15-2017, 11:10 AM
when you save a copy in 7>9 format, the audio gets copied by default(that's why the checkbox is greyed out).
"Save Session Copy In..." not working properly Meads Pro Tools 11 2 07-20-2013 09:15 AM
"Save copy in..." function copies files that have been cleared from session. ragbor Pro Tools TDM Systems (Mac) 7 02-08-2010 12:25 PM
"Save Copy In..." Never Works Properly! reichman Post - Surround - Video 21 11-12-2008 09:54 AM
HELP! 'Save Copy In" not working properly in v.7 Sebastien Bedard Pro Tools TDM Systems (Mac) 1 04-06-2006 09:51 AM
"Save Session Copy" MUST copy AIIFF files??? BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-11-2001 12:33 AM
