Re: input monitor / record issue
There is an AAF import bug in v10.3.8 that results in incorrect audio being placed on the timeline.
If you do not need to import AAFs, then v10.3.8 should be fine. I have the need to work with AAFs, plus I err on the side of conservative for these situations. That is why I recommended v10.3.7.
So I can go there
Jonathan I still have some crash during the day at different moment See the attached files
[FONT="Comic Sans MS"][B][COLOR="SlateGray"]Mac Pro Dual 6 Core Intel Xeon @ 3.46 GHz, 48Go RAM, OS 10.8.5, HDX Protools HD 10.3.10 1 x HD I/O + 1 x 192 |
I don't know enough about reading crash logs to say what is causing Pro Tools to crash. All I can tell is that it is Pro Tools that is crashing.
While that may seem obvious, there are times when another process can cause Pro Tools to crash. If you want to use v10.3.8, do a clean uninstall of v10.3.7 first.
ok thanks I'll do this tomorrow
Have a nice day
HELP
I've lost the day to try start this PT10.3.8 Crash, not going HD TDM, when TDM is on CRASH again, run tech support utility, repair permission....restart Loose again HD TDM, restart with N key not available immediately Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 com.digidesign.framework.DAE 0x0ec3b3b7 FWMidiCallback + 322151 1 com.digidesign.framework.DAE 0x0ec3b5be FWMidiCallback + 322670 2 com.digidesign.framework.DAE 0x0ec3b8bc FWMidiCallback + 323436 3 com.digidesign.framework.DAE 0x0ec3ba24 FWMidiCallback + 323796 4 com.digidesign.framework.DAE 0x0ebcdab5 FicGetContiguousMemRequirements + 100341 5 com.digidesign.framework.DAE 0x0ebcc653 FicGetContiguousMemRequirements + 95123 6 com.digidesign.framework.DAE 0x0ebcd057 FicGetContiguousMemRequirements + 97687 7 com.digidesign.framework.DAE 0x0ebc9dff FicGetContiguousMemRequirements + 84799 8 com.digidesign.framework.DAE 0x0ebc9f9c FicGetContiguousMemRequirements + 85212 9 com.digidesign.framework.DAE 0x0ec8d599 FicAcquire + 25 10 com.digidesign.framework.ProTools 0x0cd810ad MFortressHWBPEntryPoint_exit_mfort6317_ + 15864579 11 com.digidesign.framework.ProTools 0x0cd88c52 MFortressHWBPEntryPoint_exit_mfort6317_ + 15896232 12 com.digidesign.framework.ProTools 0x0d65ff9b MFortressHWBPEntryPoint_exit_mfort6317_ + 25166321 13 com.digidesign.framework.ProTools 0x0d662030 MFortressHWBPEntryPoint_exit_mfort6317_ + 25174662 14 com.digidesign.framework.ProTools 0x0d664902 MFortressHWBPEntryPoint_exit_mfort6317_ + 25185112 15 com.digidesign.framework.DFW 0x0059a78b TCommandHandler::PerformCommand(TCommand*) + 187 16 com.digidesign.framework.DFW 0x0059b0df TCommand::Process() + 31 17 com.digidesign.framework.DFW 0x00590b8a TApplication::ProcessEvent(TEvent*) + 26 18 com.digidesign.framework.DFW 0x005914a0 TApplication::WakeUp() + 64 19 com.digidesign.framework.DFW 0x006f751b TApplication::CreateNewOSApplication(void*, void*, void*) + 667 20 com.apple.HIToolbox 0x9394fc0c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36 21 com.apple.HIToolbox 0x937cb313 _ZL23DispatchEventToHandlersP14EventTargetRecP14Op aqueEventRefP14HandlerCallRec + 1602 22 com.apple.HIToolbox 0x937ca790 _ZL30SendEventToEventTargetInternalP14OpaqueEventR efP20OpaqueEventTargetRefP14HandlerCallRec + 482 23 com.apple.HIToolbox 0x937ca5a8 SendEventToEventTargetWithOptions + 75 24 com.apple.HIToolbox 0x937e01c6 _ZL29ToolboxEventDispatcherHandlerP25OpaqueEventHa ndlerCallRefP14OpaqueEventRefPv + 3152 25 com.apple.HIToolbox 0x937cb7ce _ZL23DispatchEventToHandlersP14EventTargetRecP14Op aqueEventRefP14HandlerCallRec + 2813 26 com.apple.HIToolbox 0x937ca790 _ZL30SendEventToEventTargetInternalP14OpaqueEventR efP20OpaqueEventTargetRefP14HandlerCallRec + 482 27 com.apple.HIToolbox 0x937df571 SendEventToEventTarget + 76 28 com.apple.HIToolbox 0x9394fa58 ToolboxEventDispatcher + 82 29 com.apple.HIToolbox 0x9394fb87 RunApplicationEventLoop + 236 30 com.digidesign.framework.DFW 0x00700a5b DFW_EventLoop::RunApplicationEventLoop() + 11 31 com.digidesign.framework.DFW 0x00590c5d TApplication::Run() + 45 32 com.digidesign.framework.ProTools 0x0d8a91b1 MFortressHWBPEntryPoint_exit_mfort6317_ + 27563015 33 com.digidesign.framework.ProTools 0x0d8aa6d4 LaunchProTools + 1412 34 com.digidesign.ProTools 0x0000f277 0x1000 + 57975 35 com.digidesign.ProTools 0x0001037a 0x1000 + 62330 36 com.digidesign.ProTools 0x0000effd 0x1000 + 57341
#16
Considering many (if not most) don't touch AAF import, I think it's crucial to point that out before categorically suggesting .7 as they'd be missing out on the other .8 fixes and gaining nothing in return -- a net loss for them. |
#17
That's just a screen name. You can pick anything. I was "Napoleon Bonaparte" when I first joined the forum but I wouldn't recommend taking my French classes.
I then tried "Upstanding Citizen" but still had to pass through security at the airport. I'm thinking about trying out "Einstein's Son." |
#18
Eric, are U french
I just in a stable status with PT 10.3.8 now finnaly F....nightmare, I've closed everything and restart....bingo....
#19
I'm glad 10.3.8 is finally working well for you. |
#20
a new tip
Read my post about certain weirdness today between HD 10.3.8 and ilok license manager.
Everything fine now, but could not start Pro tools without quiting. I had to update ilok stuff to 4.6.
Alécio Costa Studio High-End e-Mastering & Music Production www.aleciocosta.com http://www.facebook.com/alecio.costa PT Ultimate Native 2023.3 - Mac Mini M1 16GB RAM - Mac Os Ventura 13.2 - 2 192 IO Digidesign Digital PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 2008 16GB RAM Mastering Gear: Pendulum Audio, Crane Song, Avalon, Great River, Sebatron, Sonnox, Izotope, PSP, TC, Fab Filter. |
audio input tracks sent to one aux track - how do i monitor JUST the aux input track? | awhile | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-17-2010 07:50 AM |
green record button? "Input Monitor Only" stuck on | bluesigns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-17-2004 10:16 PM |
i want to monitor the input signal w/plugs during playback, but not record it... | Joseph Grimm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-05-2003 04:20 PM |
switch auto input and input only monitor with midiprotocol | mmestudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-27-2003 03:51 PM |
How to toggle between "auto input" and "input monitor" with PC?? | Camilo Orozco | ProControl, Control|24, Command|8 | 2 | 04-23-2001 01:05 PM |
