Old 06-05-2018, 06:26 AM
stevegalante stevegalante is offline
Default HD Native disappearing
PT 12.5 HD on Macpro 5,1 running El Capitan with a PCI HD Native card.
When I boot my Mac sometimes my HD Native just disappears from the "output device" or Audio Midi setup. Can't find the reason.
Digitest is fine.
Sometimes I have to reinstall the HD drivers to make it reappear.
Is there any procedure to kind of reset it and try to make it reappear without reinstalling the drivers and rebooting the machine ?
Interface is a Lynx Aurora(n).
Thanks
http://www.stevegalante.com
Old 06-05-2018, 09:30 AM
Default Re: HD Native disappearing
To me, this sounds like a bad connection somewhere. So, after shutting everything down, I would open the tower, pull the card, clean the edge connector and re-install. Then I would unplug>replug both ends of the digilink cable several times. I would also use a can of compressed air to blow out the PCIe slot and the connector slots in case things are dusty.
Old 06-05-2018, 01:47 PM
I'll try this... forgot to mention my Digilink cable is 50ft long. Thanks
Old 06-05-2018, 09:56 PM
BScout BScout is offline
What sample rate are you running?
Old 06-06-2018, 04:03 AM
Usually 44 or 96, rarely 48 or 88, never higher than 96
Old 06-06-2018, 04:25 AM
To this I would add get some Caig Deoxit to clean the contacts. Works better than using isopropyl alcohol.
Old 06-06-2018, 05:36 AM
Thanks for your suggestions, but do you know if there's any procedure to force my Mac to rescan for an HD native (besides rebooting or reinstalling HD drivers, etc.) ?
Old 06-06-2018, 08:53 AM
YYR123's Avatar
YYR123 YYR123 is offline
The about this Mac system profiler, is it there?
Daniel
Old 06-06-2018, 09:33 AM
Never checked when it disappears... but I will as soon as it happens again
Old 06-12-2018, 01:03 PM
YYR123's Avatar
Inquiring minds want to know........what happened Steve?
Daniel
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
FLUX Elixier V3 AAX Native & DSP + Freeware Bittersweet V3 AAX Native & DSP released psmworld AAX Plug-ins 18 01-31-2013 04:16 PM
Disappearing I/O Borg Pro Tools TDM Systems (Mac) 0 02-19-2008 11:34 AM
SSL4000 native/ Renmaxx native/ DUY everpack native!!! cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2007 07:58 AM
