Old 10-18-2004, 11:11 AM
c-post c-post is offline
Default how to make a midi track \"mute safe\" i.e. disable?
Using Mixplus 5.1.3. How can I make a Protools midi track "mute safe"? inotherwords, i have muted it, and i want it to stay "off" no matter if I option-mute and option-unmute all other tracks. Maybe there is some other command that will uniquely disable a track or put it in hiberation. I can certainly do this with audio tracks by specifying voice off. Specifying no output is a bit of a pain because whenif reenabling I have to find the proper instrument again. How to do it with a midi track??
thanxz again
-John C
"TISH! You spoke PROTOOLS! Speak some more protools, Tish... disk allocation, degree of thinning, timeline insertion...ANYTHING!"
Old 10-19-2004, 12:46 AM
M.A.I.N. M.A.I.N. is offline
Default Re: how to make a midi track \"mute safe\" i.e. disable?
Although there is no way to make a MIDI track inactive, I did find 2 solutions to your problem.
1. You could select all notes on the piano roll and mute them
- Put cursor on piano roll hit apple+a then hit apple+m
- To unmute do the same thing
2. You could make a new playlist on your MIDI track hiding the current playlist with notes
- Click the arrow next to the MIDI track name(in the edit window) select new from the popup menu
- To get the notes back click the arrow and select the first playlist exp: MIDI(1)
This should solve your dilema
P4 2.4 GHz 1 Gig RAM
DIGI 002, Reaktor 5, Reason 3, Waves Gold
Slang Music Group
Old 11-21-2004, 06:25 AM
sgsg sgsg is offline
Excuse me for my question.... How I can disable an audio track in protools LE???? There is also a keybord shortcut?
This is my dilema....
SgSg
Old 11-22-2004, 08:30 PM
Simply click on the little box and select off. That shuts that voice off(in the left-most box-edit window.)
main.mute-safe (in general...) xcx VENUE Live Sound Systems 6 01-22-2014 02:15 PM
All mode - way to disable mute? BigBadBill Pro Tools TDM Systems (Mac) 2 10-09-2009 04:32 PM
Is there a way to disable Mute Automation corym Post - Surround - Video 7 09-10-2009 10:12 PM
Mute Safe Jim Roach VENUE Live Sound Systems 3 04-11-2008 02:13 PM
how to make serial port available for machine control and disable it's MIDI function? c-post Pro Tools TDM Systems (Mac) 7 08-05-2002 12:49 AM
