Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 02-16-2010, 02:21 PM
KyleACounts KyleACounts is offline
Default Would these specs run Pro Tools Essential smoothly?
Would these specs. be able to run Pro Tools 8 LE smoothly?
SPECS:
AMD Athlon™ II X2 Dual-Core Processor 250u1
Genuine Windows® 7 Home Premium 64-bit2
NVIDIA® GeForce® 6150 SE
4GB DDR2 dual-channel3
750GB 7200rpm SATA4
16x DVD±R/RW SuperMulti drive
Old 02-16-2010, 03:10 PM
necjamc necjamc is offline
Default Re: Would these specs run Pro Tools Essential smoothly?
For starters you will need a second, either FW or internal 7200 RPM HD for audio.
USB drives don't cut it. For a more detailed idea you should post a Sandra report.
Old 02-16-2010, 04:04 PM
sunburst79 sunburst79 is offline
SPECS:
750GB 7200rpm SATA4
Same answer as your other thread. No.
The requirements for Essential are a little lighter but the 6150 chipset is a deal breaker with PT.
Any version of PT
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-17-2010, 08:45 AM
conholster conholster is offline
Any version of PT
Thats basically what I'm running (PT ess. 8.0.3). Except I've got DDR2 and cpu is AMD x2 240, ati chipset. Care to elaborate why not? You mention another thread, link? Thank you :)
Old 02-17-2010, 09:08 AM
Aaahh, OK I see
Sunburst79 wants you to belive that unless your computer costs megabuck$ it wont be any good. The only hardware requirement for PT m-powered is a minimum of 1GB or RAM and a computer screen that can do a minimum resolution of 1024x768. That's about any computer made in the past 3-4 years. $600 is more than enough to get a working system.
Old 02-17-2010, 02:36 PM
DigiTechSupt's Avatar
Originally Posted by conholster View Post
Aaahh, OK I see
No, actually Sunburst79 wants you to believe that compatibility is important - because it is.
The hardware requirements for M-Powered are the same for LE and they are very specific. Here's a link with information on compatibility for Vista (with a link to XP, if you prefer). Win7 is likely the same requirements as Vista, but has not been fully qualified yet:
http://digidesign.com/index.cfm?lang...4&itemid=29586
Avid Audio Tech Support
Support FAQ
Is anyone having 10 run smoothly? Rocker4301 Pro Tools 10 38 03-06-2013 03:19 PM
My PT Essential M-Powered Essential Stops during the recording j-guitarist Pro Tools SE and Essential (Win) 0 01-18-2010 02:48 AM
This is JUST what we NEED! NOT!!! Pro Tools Essential and Structure Essential audiogeekzine General Discussion 273 09-30-2009 08:26 AM
Can LE 6.9 run smoothly on OS 10.3.5? SonicSupreme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-24-2005 12:55 AM
so once I get this PT will run smoothly? getemup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-27-2005 12:04 PM
