questionable quality of Euphonix Artist Series?
I received a MC Mix demo unit from an official Euphonix distributor. The top surface was deformed so much that it partially blocked movement of two faders. Please take a look at these pictures: http://www.chimpstudio.com/euphonix/
Have you ever encountered this kind of misshape on Euphonix artists series? Could that be overheating problem? This unit came from a distributor.... Is this how MC Mix is going to look like after a few months of use?
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
Re: questionable quality of Euphonix Artist Series?
Definitely not - well, not that often. We've seen a couple of cases of this - is this a v1 or v2 unit (v2 units have a black jog/shuttle wheel)?
In any case, either you dealer can swap it out or, once you register, just start a support case and we'll have someone contact you for a replacement. |
Well - it's MC Mix and I am not sure if it was V1 or V2 because it doesn't have jog wheel :)
The demo unit came from local distributor in Poland - MBS. I was actually going to buy it, as I expected a demo unit from authorized dealer to be in a decent shape. Once I saw the problem (which you can see on the pictures) I sent it back straight away. I did not even plug it in. They only said "sorry" and have never offered me any replacement, despite the fact that I told them I was very angry (in a polite way of course). Right now I am looking for a MC Control on eBay from UK or Germany. As much as I love my country - many dealers here are completely hopeless.
We had one mix crack spontaneously while not being used.
I've been waiting 1,5 month now for my second MC Mix. Perhaps they are doing some much needed changes in the mounting process at the plant, changing the rotary encoders, reconstructing the fader caps, reducing noise on some units, change the brandname to Avid and so on... Any rumours?
A totally different issue, that is on the programming side, is how the EU-control acts after the computer has been in sleeping-mode and you start it up in the morning - very enervaiting! There also need to be some joint power circuit/ethernet solution for 4 - 6 units on offer. (The only senseble way would have been to have it built in from the start, including an Airport solution - since that works obviously well...)
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8, Digi002 Fact., Logic X|FCPX|Motion Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix |
Pro Tools does not support Sleep. Your installation guide says no not let the computer Sleep.
"3 Set the Computer Sleep setting to Never. 4 Set the Display Sleep setting to Never." You could use an inexpensive Ethernet router to connect multiple units. $20 http://www.amazon.com/D-Link-EBR-231.../dp/B000GVTX6U Avid suggests turning off Airport when using PT. I would not want a controller to operate wirelessly.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
I turned to this solution (over others that would have worked better for pure Pro Tools use), because of its openness to different modus operandus. I was also very aware off the fact when I bought the unit, that the touchscreen of the Control will/could soon be outmanouvered by the iPad if the developing team of Avid/Euphonix isn't smarter, wittier and read the needs and want's of the music/video/post costumer base better then the App-store newbies???
at the price these things run is a solid aluminum surface that does not crack or bend in order? uhhh yes it is, as well as fader caps that stay put...
times are hard for many of us, I would not spend my hard earned cash on a product like this, I am sure your profit margin is great, see how it works out for you in the long run... good lord, a $200 gasp BEHRINGER is built better....thats just sad avid.... |
Some newer production run with Avid sticker on the box are more expensive but the build quality is worse... Fader noise is killing me...
My studio is about to get one of these systems over the c24 because of multi platform usage such as nuendo, logic and pro tools...
As I have read, Im very worried due to the quality of this product, and I dont understand why Avid would let this slide??? From what i hear is its a plastic piece of junk....I hope avid listens to the masses and changes the build of these units quickly... I wish avid would make the c24 usable with other recording software - then we would buy it....we use Nuendo and protools |
New Euphonix/Artist Series Install | guitar012001 | Artist Series | 5 | 08-30-2012 10:51 AM |
D Command or Euphonix Artist series? | michael c | ICON & C|24 | 5 | 12-25-2011 10:52 PM |
Euphonix artist series | gsonsstudio | Artist Series | 2 | 04-01-2011 01:22 PM |
Euphonix Artist Series 20% off at audiomidi.com | nst7 | Artist Series | 0 | 11-18-2010 10:06 PM |
Euphonix Artist Series PC Compatibility | Cloud_9 | General Discussion | 7 | 04-20-2010 09:48 AM |
