Top|Back not closing plugin like Eucon 3.6
A common workflow for me would be, press EQ on the S3, make some adjustments, and then press Top|Back to close the EQ. Since updating to 3.7, this no longer works as the menu returns to the top on the S3 but the EQ remains open. Is this an intentional update? Can we get the prior functionality back?
OSX 10.12.6 PTHD 12.8.2r2 Eucon 3.7 Avid S3+Dock Last edited by ripekeai; 10-30-2017 at 08:48 PM. |
Re: Top|Back not closing plugin like Eucon 3.6
That is working as it should here on 3.7
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 |
Can you check the General tab in EuControl and make sure the Close Plugins when editing is checked. If it is toggle it anyway to make sure.
I had the same issue and what works is toggling like Eddie said. I only had to do it once, so it’s not like every time you shut the computer down you’ll have to do it. It worked for me and I hope it works for you. Let us know if it does!
Although I never deliberately unchecked, it was in need of a check. Didn't realize that was an option so thank you for the resolution.
I’m glad you got it sorted out
Pro Tools hangs when closing plugin window | George2000 | Windows | 6 | 09-12-2017 03:26 PM |
Plugin written automation is gone after closing protools | sabinacovarrubias | Pro Tools 12 | 1 | 06-29-2017 12:42 PM |
Top/Back button not closing plugin? | Tim R. | Avid S1, S3, Dock and Control App | 5 | 02-12-2016 08:26 PM |
PT 11 Crashes While Playback When Closing Plugin Windows | SpaghettySaussage | macOS | 0 | 10-26-2014 09:46 PM |
Key command for closing plugin windows? | IO Composer | Pro Tools TDM Systems (Mac) | 9 | 08-10-2009 04:38 AM |
