PT M-Powered + Alesis Multimix12USB
I'm have a problem recording my vocals in Pro Tools.
I have my M-Audio 2496 outputs running to my Alesis Mixer Input. I also have my Mic In on my Mixer. When I get ready to record audio, the beat is recorded with the vocals. Can someone help me with my setup. How can I set my equipment up to where I can record vocals without the beat behind it. Do I need another pre-amp or can I use my current setup. Any help is useful. Thanks a lot. East Ova... |
Re: PT M-Powered + Alesis Multimix12USB
need more info...what is the source of the beat? is it loaded into pro tools in its own track?...is it coming in from an external sequencer or keyboard?...
everything is on it's own track. I would create a new track for my vocals and before I record I would test my levels and the track sounds will jump in the track I have for my vocals. Or if you could suggest something I could use with my M-Audio 2496 to record my vocals with that would be find also. My mixer is for my MPC anyways, but I had to hook up outs from my soundcard to my ins on my mixer to be able to hear anything through my headphones. Any help would be great
Assign the vocal channel(s), and nothing else, to alt 3/4 on the mixer.
Connect the alt 3/4 outputs from the mixer to the line inputs on the 24/96. Now any channels assigned to the alt 3/4 busses will be recorded and any assigned to the main mix will not. Using the switching matrix on the headphone/main section of the mixer should allow you to hear everything. Hope this helps, Jack |
Alesis QX49, Akai Pro MPD18 & pro tools m powered will they work? | mattshee643 | Pro Tools M-Powered (Win) | 0 | 02-17-2012 01:39 PM |
mac osx, m powered fast track, pro tools m powered | singdance6 | Pro Tools M-Powered (Mac) | 2 | 12-22-2010 09:24 AM |
ProTools M-Powered 8.0.3 with Profire 610, Axiom Pro 61 and Alesis Mastercontrol | Enrico Pallazzo | MIDI | 4 | 11-10-2010 01:00 AM |
Please Advise are Pro Tools M-Powered Essential the same as LE M-Powered? | jeremiah0812 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-19-2010 10:10 AM |
Synchronizing Alesis HD24 to Pro Tools M-Powered 8 | Rampart1 | Pro Tools M-Powered (Mac) | 11 | 01-18-2010 06:42 PM |
