Old 03-04-2003, 08:15 PM
Jerry K. Jerry K. is offline
Default File Sharing w/ DP3
Hello, I am wanting to share a project with a friend who has Digital Performer 3. My project will have MIDI and audio tracks, can this be done. Thanks
Jerry Kelley
[email protected]
www.jlkstudio.com
Old 03-04-2003, 10:52 PM
Bastiaan Bastiaan is offline
Default Re: File Sharing w/ DP3
As far as i know DP is mac only. You may get more replies posting this in the mac-forum...
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 03-04-2003, 10:58 PM
Export the MIDI as a Standard MIDI File.. and the audio from bar 1 as continuous audio files.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-05-2003, 10:08 AM
So if I export the MIDI as its own file, should I export the audio as .wav or SD2 files. He can read both, I don't know if there is an advantage to either of the formats.
Jerry Kelley
[email protected]
www.jlkstudio.com
Old 03-05-2003, 10:42 AM
SD2 is not an option on the PC.
Rail
Platinum Samples
Old 03-05-2003, 10:48 AM
I would assume that if I export the MIDI from the begining as well as the audio, the two will line up when imported into something else, is this true? Thanks for your help.
Jerry Kelley
[email protected]
www.jlkstudio.com
Old 03-05-2003, 11:04 AM
The SMF Type 1 file should include the tempo info, and all the MIDI tracks.. so it'll define your bar 1. When you now import your audio - just place it at the right bar number.
Rail
Platinum Samples
Old 03-05-2003, 11:14 AM
Rail, thanks for all your help! [img]images/icons/cool.gif[/img]
Jerry Kelley
[email protected]
www.jlkstudio.com
File Extensions/Windows File sharing Bjorn Viktors Pro Tools TDM Systems (Mac) 1 07-06-2004 10:06 AM
Mac &PC File Sharing? sugarfuzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 02-12-2003 09:55 AM
file sharing between 2 macs coleslaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 06-09-2002 12:59 AM
File sharing between Mac and PC francona Pro Tools TDM Systems (Mac) 1 07-17-2001 03:20 PM
