Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 06-11-2019, 07:30 AM
Ross McGoo Ross McGoo is offline
Default How do I export something Quicktime will play on the iMac
I'm new at this, obviously.
The AIFF format that ProTools 19 offers as the only export option is not seen by Quicktime. I tried down on the lower part of the export dialog box, and it diced the file into about 15 pieces.
Surely, there's a simple way to export a file so you can play it back or send it to someone.
Can some kind soul point me to a tutorial on this or just lay it out in a response?
Thanks!
Old 06-11-2019, 07:31 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: How do I export something Quicktime will play on the iMac
Hi, welcome to the community.
Bounce.
Janne
Old 06-11-2019, 07:57 AM
Are you trying to bounce a multitrack mix or export a clip or commit a single track?
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 06-11-2019, 08:00 AM
Ben Jenssen's Avatar
Quicktime player can open lots of file formats. Right-click on the file in Finder and select "Open with... other application" select quicktime player and choose "Always use this" (or whatever it says in your language). That file format will then always be handled by quicktime player.
Old 06-11-2019, 09:18 AM
gfantsimon gfantsimon is offline
You wrote that AIFF is the only format Pro Tools will export... that's not correct... In Pro Tools, you don't use Export, you use Bounce to Disk. It's under the File Menu... You highlight the beginning and end of the audio you want to export first, then choose Bounce to Disk and choose the Wav file format. Most video uses 48k... So bounce a Stereo Interleaved Wav File at 48k... Hope that helps. Gina
Export QuickTime Movie Ian Palmer Post - Surround - Video 11 04-06-2019 02:36 AM
Export QuickTime Movie Ian Palmer Pro Tools TDM Systems (Mac) 2 03-23-2010 01:23 PM
Quicktime Crash on Export to Quicktime Movie Yosemite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-28-2007 12:44 PM
Quicktime export tj_davies Pro Tools TDM Systems (Mac) 5 03-21-2007 12:19 AM
How to Export Quicktime to VHS (inexpensively) marka123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-29-2001 12:02 AM
