Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 04-12-2019, 04:54 AM
SteSo SteSo is offline
Default Eucon Surfaces EQ Dyn Cycling
I´ve upgraded to PT 2018.12.0 and was very pleased to see a function in PT Mixing Preferences under Controllers called Eucon Surfaces EQ Dyn Cycling Starting at insert x.
As I´m using the Channel Strip in slot a, my PT-Control always recalls the Channel Strip Plug In by pressing Dyn and Eq. On slot b I do have a compressor and in slot c I do have a Fabfilter. My hope was to start Cycling with slot b, I would have a chance to recall the compressor by pressing Dyn and the Filter by pressing Eq without the detour pressing Inserts and than selecting the insert I want to work with. I have a dock and two Artist Mix, still running mac os 10.10.5 for some reasons. Does anybody else has experienced this? Or does this feature not support the Dock with PT-Control?
Thanks, Stefan
Old 04-13-2019, 08:31 AM
EddieJones's Avatar
Default Re: Eucon Surfaces EQ Dyn Cycling
This is for S6 at the moment. I want to add it to the other surfaces sometime in the future.
Old 04-14-2019, 03:55 AM
Hi Eddy,
thanks for your reply, would be highly appreciated.
By the way, do you remember my suggestion to have the possibility to switch off the shift mode for the artist mix in EU-Control, so that there are no longer transport functions on Solo and On buttons?
Cheers, Stefan
Old 04-15-2019, 11:09 AM
EddieJones's Avatar
I do....I wonder just how many people use them...I doubt any. It might be easier to remove them completly
Old 04-15-2019, 02:42 PM
I wouldn’t complain about that.
Old 04-19-2019, 10:11 AM
studiosus studiosus is offline
hi there,
yes, that would be great to deactivate these shift transport buttons! if solo and mute could stay also in shift solo and mute, that would be very helpful.
Upgraded to PT 12.8.3 & Lost EUCON Surfaces jphaudio Artist Series 2 12-22-2017 01:02 PM
Why is there still no Auto Plugin Focus for Eucon Surfaces? bobbyguelz Pro Tools | S3 5 03-22-2016 04:45 PM
S3 not showing in Eucon surfaces Avid2015 Pro Tools | S3 7 11-30-2015 12:30 PM
Multiple Eucon Surfaces with Ableton Live? djmichaelwenz Artist Series 1 09-29-2015 10:11 PM
BUG ?? Eucon 3.1.3 still sees surfaces from disabled Network Interface bernhard Artist Series 0 08-20-2014 09:51 AM
