Old 04-05-2019, 06:45 AM
TheJester TheJester is offline
Default Pro tools 11 hd working, pro tools 10 hd giving errors
Hello, really hope someone can help. Been running pro tools 11 and 10 hd co install for almost 5 years, no problems, not one. Until I tried opening 10hd the other day, got 2 errors which I took pictures of, figuring it needed an update I updated my I lock to the latest one, still got the errors. So I did a clean installation of the newest 10hd update, and getting another new error! And the same 2 originally. I need this fixed asap, please someone help me I'm literally ripping my hair out atm......thanks. windows 7 pro, i7 3930k, sabertooth mb, Samsung pro 840 system drive, wd black hds, 64 gb ram . 11hd still works perfectly, need 10 for older plugins and files. Thanks.
Old 06-07-2019, 07:23 AM
sw rec sw rec is offline
Default Re: Pro tools 11 hd working, pro tools 10 hd giving errors
Is USB power management disabled? It needs to be.
Old 06-07-2019, 08:38 AM
Agreed on USB Power Management(sometimes certain tweaks get reset by Windows). Also, I remember a while back(not sure if I was on 11 or early 12) when several Windows systems(mine and 2 others I knew) had an issue of PACE not starting. Next time this happens, open Task Manager>Services tab and scroll to PACELicenseDServices. If it shows that its Running(Status column), then I'm lost as well. If its NOT running, you can start it in that window. Normally, I'd suggest updating iLok software, but with some older stuff like you run, I would clone or save a drive image first
8 Core Mac Pro giving unexpected CPU overload errors Ed@bersey.com macOS 28 08-26-2017 11:38 AM
Pro Tools Keeps giving me this message. hotburgers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-16-2006 01:02 PM
Pro tools is giving me an Error masoth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-30-2006 12:01 PM
Pro Tools giving me a lot of problems zaviere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-23-2006 11:12 PM
Live giving me errors after 5 minutes of use digi-mike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-05-2005 08:33 PM
