Old 02-25-2013, 03:54 PM
MadDogRunner MadDogRunner is offline
Default System Requirements and full System Setup
What are exactly the PT 10 System Requirements for Windows 7 ?
I am unsure after having read the User Guides, it says sthing about Digibase or a test, and besides I am uncertain as to if there's a problem in running PT on 1 HDD where there's a partition for the OS, one partition for Projects and the last partition for Soundbanks and Loops and so on.
Help would really be appreciated.
Old 02-25-2013, 05:13 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: System Requirements and full System Setup
You really need a second physical sessions hard drive for optimum Pro Tools performance, and having a third drive for sample libraries would be even better. Here's a link to the hardware requirements:
Pro Tools 10 System Requirements
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.5
Old 02-25-2013, 05:44 PM
What he said^^^^ 2 separate drives is the minimum, unless your sessions are really small(like 8 tracks or less). Recording to a partition of the same drive with the OS is worse than just recording to C:. Look at it from the tech side; there is 1 read/write head on a platter(inside a hard drive), regardless of how many partitions, and it has to constantly move to retrieve data(for OS function), so if you ask a single drive to do OS and recording, now that head must take care of OS needs, AND streaming playback, AND writing new audio(during a record pass)! Not a good way to get performance. Now with an SSD(which are now approved for recording), it may be a different story, but a $200(sale priced) SSD has about 256GB of available space, while the same $200 will buy a pair of 1TB WD Caviar Black drives(an excellent choice for recording). Spend your money as it suits your needs, just consider all the options
BTW, if you use HD software or the CPTK, AND your system has lots of RAM(8GB or more) then you allocate some RAM for caching audio, which gives a boost in performance, no matter what drive you record to.
"No-Lo" System Requirements moblues Post - Surround - Video 10 07-15-2008 04:29 PM
system requirements brandonstevens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-22-2008 04:09 AM
Full MIX4 system on OS9 or LE system on OSX? Ricardo22 Post - Surround - Video 17 03-08-2005 07:03 PM
system requirements meter7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-19-2004 08:32 PM
system requirements greilboerg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-26-2002 03:14 PM
