Old 03-02-2012, 02:50 PM
Scott Fahy Scott Fahy is offline
Default Venue and PT10
we upgraded to PT 10 and cannot get them to talk to each other. Venue link is active but when you try to add a new session using Venue PT says that there is no I/O configured. I am NOT a PT user so I need the basics on how to do this.
Thanks
Scott
Old 03-02-2012, 03:11 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: Venue and PT10
Hi SCott,
The first thing to check is that the I/O paths are in place. Before creating a new session, choose Setup > I/O within Pro Tools. For troubleshooting purposes I suggest you select all input paths, and delete them. Then click the default button. This effectively rebuilds the I/O setup. Do the same for output paths.
More info in the Live Recording Guide.
See p.16
Sheldon
Old 03-02-2012, 03:58 PM
Deleted all paths, hit default and zip zilch. Tried to open a previous PT file that was created in 9 and Export the I/O settings then using that in the new PT 10 file and still get a box that says "There are currently no interfaces in I/O Setup which are known to connect to Venue" and below that it says "If your interfaces have been connected to VENUE, open I/O setup, then double click on the interface name (such as "A") and change it to a name like "Stage 1 17" (meaning its inputs are connected to VENUE Stage Rack 1, beginning with input 17).
I did all that and it does not make any difference
Old 03-02-2012, 04:12 PM
Update. When our IT department installed PT 10 they changed the playback engine to Built In Output, I switched it back to HD Native and all looks groovy now. I think I need to take a basic PT course.
Live recording from Venue Profile possible with Digico UB Madi & PT10 CPTK? briancares VENUE Live Sound Systems 2 09-11-2012 08:04 AM
PT10.0.1/Venue SC48 Al Rettich macOS 0 05-07-2012 02:24 PM
New webinar: Meet the VENUE SC48 Remote System, Stage 48, and VENUE 3 bobcats VENUE Live Sound Systems 2 03-24-2012 07:35 AM
PT10 and beyond. What does this mean for Venue? Roland Clarke VENUE Live Sound Systems 6 02-27-2012 12:32 PM
VENUE D-Show 2.8 Standalone Software for VENUE SC48 Avid VENUE Live Sound Systems 0 05-13-2009 12:30 AM
