Old 09-20-2007, 07:37 AM
dmh dmh is offline
Default How do I convert my 16-bit pro-tools session to 24-bit ?
I have some older songs that I originally recorded in 16-bit. I would like to re-record in 24 bit, but don't want to start over with a new file (don't want to loose the arrangement or plug-in settings, etc). Ideally, I'd like to be able to convert my current Pro-Tools LE file (7.3.1cs4) from a 16-bit file to a 24-bit file and increase the sample rate from 44.1 to 96Khz. Naturally, after the conversion, I intend to systematically re-record each track. Is there anyway to do this without having to open a new 24 bit file then import each audio file seperately?
Old 09-20-2007, 10:32 AM
dave2005 dave2005 is offline
Default Re: How do I convert my 16-bit pro-tools session to 24-bit ?
Dont you just go into "save as" and put in 24 bit?
Old 09-20-2007, 04:47 PM
Or import the old audio files into a new 24 bit session.
Old 09-21-2007, 11:59 AM
xx1messxx xx1messxx is offline
When you do either of these techniques, does it do anything to the sound of the 16-bit files? I have always wanted to do this, but thought that if you converted a 16-bit sound to 24-bits, it would really mess up the sound. I record my initial session on a Mackie 24/96, and the max bit rate I can use is 16-bit, but I have heard that guitars really sound a lot better when recorded at 24-bit. So my plan was going to be to record the drums in 16-bit, convert them up to 24-bit, and then record the guitars, bass, and vox in 24-bit. Does this make any sense, or would I be better off just continuing the session at 16-bit, until I can afford an interface that will allow me to record at 24-bit direct into protools?
Sorry to hijack the question, but hopefully the answers will be helpful to both of us!
R
Old 09-21-2007, 04:34 PM
M.Brane M.Brane is offline
When you convert a 16bit file to 24 all you are doing is adding empty bits to make up the difference. If you're going to be doing any additional processing to the files this is a good thing. The added bits will not degrade the sound.
I would think that it would be a lot better to record things with wide dynamic range like drums at 24bit. Most guitar sounds have less dynamic range than drums, unless your talking about a bright/punchy bass.
Old 09-25-2007, 01:30 PM
I've heard that recording Guitars at 24-bit, it really clears them up and makes them shine. Eventually I am planning on updating to a Digi003 with a Firewire preamp so I can get the 8 additional tracks, and then record even the initial sessions at 24-bit. Unfortunately, I was not able to do it before we were planning on recording our new album, so I am looking at the work around. Next year, I will be all set, though!
Old 09-25-2007, 04:29 PM
Given the same quality converters I seriously doubt you could hear any difference between a guitar recorded at 24, and 16 at the same input level.
Old 09-28-2007, 12:17 PM
Camilo Toledo Camilo Toledo is offline
Realistically, our normal average ears will not hear any difference even if you convert to 24 bit 96kHz. Specially with the semi-pro convertion on the devices we use. That simply said, If you started a session at 16 bit 44.1kHz keep it that way.
Camilo Toledo
Can anyone convert a Pro Tools session for me? jv2612 macOS 16 07-01-2013 07:54 AM
Convert session from 44.1 to 48 k ? chaosdemonz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-07-2012 05:07 AM
Way to Convert Session Bit/Sample Rate??? From Within Session??? Table Syrup Records 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-25-2011 09:48 AM
convert session SupreGlu Pro Tools TDM Systems (Mac) 5 11-04-2010 06:52 PM
Convert Mac (LE 5.x) session to PC (LE 6.9) ... bigbottombass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-06-2005 12:06 AM
