Old 04-04-2007, 04:07 PM
mforehand mforehand is offline
Default Bouncing Issues...SERIOUSLY?!?!?!
MacBook Pro/002R (recording through external HD - which has been set-up through the Workspace as a Recordable volume)/10.4.9 Combo Update
So, here's my issue. I'm doing a Bounce To Disk (24-bit, 48k) with Convert After Bounce selected. I'm bouncing to my Desktop. It seems as though the bounce completes fine, until I get this dialog:
Could not complete the Bounce To Disk command because Assertion in "/Volumes/Development/vb_cliff/AlturaPorts/NewFileLibs/FileFormat/MacBuild/../../FF/Audio/FF_AudioProperty.cpp", line 33
WTF? I've never ever seen anything like this in my, God knows, how many PT years!! So naturally, I did the things that they always tell you to do...trash the stuff in the Digidesign Databases (volume, etc.). Still...nothing. So then I went looking for said "Assertion", only to come up empty (not that I thought I would be successful).
I tried copying the session to my system HD, but got the same result. Is it some kind of corruption in the audio files or the session?
So, now I turn to you guys. The gurus and shamans of my digital world.
I'm so confused. My client is pissed. I'm having to "Sub-Mix" the entire track to a stereo audio track and then "Export Files As". I mean, its basically doing the same thing, but its so very inconvenient. Please help? Someone?!?!?! I need an adult I need an adult!!
Thanks in advance,
Michael
Old 04-04-2007, 05:21 PM
Neesley Neesley is offline
Default Re: Bouncing Issues...SERIOUSLY?!?!?!
I get these assertation errors ALL THE TIME!
Jeez.
The only remedy I've found is to slightly increase or decrease the bounce length by 15-20 milliseconds, more or less. Works EVERY time.
Also - Make certain you are using only one processor for RTAS. For PowerMac G5, anyway.
It's all a bit of vodoo as far as I can determine. My tricks work for me and a few others but not universal, to be certain.
MacBook Pro 2.7 gHz i7, PT9 HD, Mackie ONYX Blackbird, AMEK/Neve 9098 Preamps, Schoeps mics
Old 04-04-2007, 05:54 PM
I adjusted my playback options to use only one of the two processors in my MacBook Pro, and lo-and-behold it worked. Hmmm...I've never heard of this issue. Maybe I missed something.
Oh well. Thank you SO much for helping me with this. Looks like its not going to be as long a night as I had originally thought.
- michael
Old 04-05-2007, 10:27 AM
rdeardorff rdeardorff is offline
I've found that reducing the playback buffer size usually solves this issue.
Old 04-05-2007, 11:11 AM
DigiTechSupt's Avatar
This is usually caused by having the DAE Playback Buffer at level 8 - try setting it at level 2 or 4 and the error should go away.
Avid Audio Tech Support
Support FAQ
Old 04-10-2007, 12:59 PM
tomorrowstk tomorrowstk is offline
I have heard that if you delete the fades folder where the session you are working on is stored will fix that error as well. I had the same issue about a year and a half ago....deleted the fades folder and it seemed to work. I would try buffer settings first off though.
Bouncing Issues McLuckie Pro Tools 9 7 04-12-2013 06:51 PM
Bouncing issues pjmusiced Windows 0 05-04-2012 12:13 AM
Bouncing Issues benplaysmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-31-2011 10:00 AM
mp3 bouncing issues bfxp Pro Tools TDM Systems (Mac) 3 05-25-2006 02:32 AM
Digital Bouncing Issues Ang1970 General Discussion 6 04-20-2000 05:58 AM
