#61
Re: Automation AppleScripts for Pro Tools (Mac)
one thing I'm noticing with my script, it have some temperamental behaviour, it works and do what I want 10 times, in the same test session, then from some reason it stop doing one or two things.. I do reboot, do it again and it work fine for some time. weird. Code:
update Worked like a charm, I just need to check the exact name that the set command result gave and voilá :)
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro Last edited by Marco Bernardo; 02-18-2016 at 06:27 PM. |
#62
Oliver and Zoff THANK YOU
Here it is what I've done Click here to see the video Tomorrow need to add this to a 19" resolution Thank you once again
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro Last edited by Marco Bernardo; 02-18-2016 at 07:06 PM. |
#63
the video won’t show, its private. Anyway, when using the method I described above and executing the click by position, you do not need coordinates, nor do you need handlers for different display sizes. Attached is an example script, it opens the Playlist Selector of Track 1. For some reason the board didn't allow me to post the code, weird. |
#64
Ive edit the link of the video it should work now. I didn't have time to test that option but I will do it today :) for sure, your way seems more bullet proof . Thank you so much Oliver
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro |
#65
Hey Oliver! Thanks for giving us ur app..
I've 1 question.. Maybe it's already possible but would u say it could be possible to paste Plug in settings from AAX plugs to their corresponding Audiosuite plugs; just with using short cuts?? Thanks for info in advance!! All the best! G.
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD |
#66
#67
Hi Oliver,
Done, ok ok ok almost done!! Definitely this Code:
set {xPosition, yPosition} to position set {xSize, ySize} to size There's only two small things that I've managed to get it done but I know is not "bulletproof". Click here to see the video THANK YOU!!!!!! ps: now I'm cleaning code, to much tell and end tells that can be avoided
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro Last edited by Marco Bernardo; 02-21-2016 at 02:07 PM. |
#68
Thnx for response.. I'd need "copy plugin settings from aax plugs and paste them to audiosuite plugs - ideally with one shortcut - because it would be a huge time saver when phase aligning different clips from different mic positions...
Thnx again! Quote:
#69
#70
Now I'm trying to do a loop with a choose list (infinite until I enter cancel)
I already did this Quote:
even for cancel I need to cancel it 3 times ehehe
Pro Tools 12 Trim Automation | [email protected] | Pro Tools 12 | 2 | 08-16-2015 04:25 AM |
Pro Tools 11.2.1 Automation Bug?! | Gneal550 | Pro Tools 11 | 1 | 11-22-2014 01:15 PM |
GRM tools automation bug? | D'Animation | Pro Tools TDM Systems (Mac) | 6 | 10-08-2014 08:21 AM |
scripting Pro Tools; automation | Bermaster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 10-01-2004 12:38 PM |
AppleScripts and other Macros for PT | Bergeron | Tips & Tricks | 1 | 11-15-1999 06:55 PM |
