Cmd+W doesn't closes import window without importing
Hi guys,
ever since upgarding this doesn't work anymore. In the audio import window, we use Cmd+C to convert the audio file we want and then we used to be able to Cmd+W to close the window and the import would happen. Now it only closes the import window without importing the selected audio? Is there no such shortcut anymore or do I need to set something in the apple keyboard prefs? Cheers, Tim |
Re: Cmd+W doesn't closes import window without importing
Are you on the latest version of Pro Tools? or on 2020.12?
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
Have you tried just pressing "Enter" on the numeric keypad?
~Will |
Yes, we're on 2020.12 Is this a known problem with that version? Cheers, Tim Gesendet von iPhone mit Tapatalk |
Group modify window can't be opened, closes itself right away NEED HELP | joren | Pro Tools 2019 | 3 | 04-25-2024 02:00 AM |
Plugin window closes | pasanta | Pro Tools 2019 | 3 | 08-22-2021 02:07 PM |
MC Control V2-Do you know why when I select a Track the plugin window closes? | Zak7 | Artist Series | 1 | 02-17-2021 08:08 PM |
PT closes on Import Audio | SteveGarman | Pro Tools TDM Systems (Mac) | 1 | 02-07-2006 03:47 PM |
Plugin window closes sudenly unable to recover | Dan002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-13-2005 08:10 PM |
