Old 05-22-2020, 09:58 AM
goodfellamikec goodfellamikec is offline
Default Collapse Folder on Artist Mix?
Is there a way to expand or collapse folder tracks directly on the Artist Mix? Or is the only way to use the mouse or tap the button on the iPad?
Using PT 2020.05 and Eucon 20.5.0.149.
Old 05-22-2020, 11:06 AM
EddieJones's Avatar
Default Re: Collapse Folder on Artist Mix?
At the moment no. Use either the new Softkeys or the racks page o the Control App. Folder Spill is coming soon so you will be able to double tap Sel to spill the folder(and optionally open and close it at the same time)
Old 05-22-2020, 11:11 AM
Looking forward to it. That will be uhhmazing!
Old 07-31-2023, 08:17 AM
nd nd is offline
Has this been implemented?
Doesn't seem to work on my Artist Mix...
Old 07-31-2023, 09:43 AM
EddieJones's Avatar
Yes this was way back in v20.11. Do you have Avid Control too, does spill work from that. (FYI this is a PT only feature)
https://resources.avid.com/SupportFi...l_v2020.11.pdf
track folders collapse on s3? grant howarth Pro Tools 2020 5 05-11-2020 06:59 AM
Possible to have VCA spill/collapse on soft buttons? stefanboman Avid S4/S6 7 12-03-2018 08:42 AM
Collapse Audiosuite Plugin Window mikevarela Post - Surround - Video 8 05-20-2014 08:11 AM
How do I collapse an empty playlist?!?!? StinkyStan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-21-2009 02:22 PM
EZ way to collapse surround to stereo mix? babyseal Pro Tools TDM Systems (Mac) 1 06-22-2000 04:51 PM
