OMNI Mixer "Mutes" function not working
I have 2 identical setups and one of them the "Record / Input Mutes Mixer" functionality won't seem to work…
I have re-flashed the Firmware to 2.10, reset the unit twice… Anyone have any ideas?
Brian Dozoretz ACSR ACI Dolby Atmos Mac Pro, os12.6.3, PT 22.12 HDX, 2xAlphalink,1xDeltaLink, Mac Mini, os12.6.3, PT 22.12 HD Native + HD Omni, Artist Series Mix x 2, Artist Series MC Transport, Atmos 5.1.4 VENUE SC48 3.2 with iPad Control SSL Duality SSL Duality via ipMIDI / ∂elta Automation Plug-In |
Re: OMNI Mixer "Mutes" function not working
I know this is obvious, but did you check to see that you are enabling the same inputs as the mixer? Ie if you input monitor 1/2, signal going into 3/4 will still play through the mixer.
PT's 10 Crashes when performing "Save Copy In" function | soundguy69 | macOS | 2 | 07-07-2015 10:01 PM |
Omni causing "Creating DAE object" hang on boot-up | sharp11 | Pro Tools HDX & HD Native Systems (Mac) | 3 | 03-04-2013 07:57 AM |
"Save copy in..." function copies files that have been cleared from session. | ragbor | Pro Tools TDM Systems (Mac) | 7 | 02-08-2010 12:25 PM |
quick question about adding "Mutes" | Cali Hendrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-21-2003 11:58 AM |
MIDI "mutes" when switching from Logic to PT | jeremyroberts | MIDI | 2 | 06-27-2002 07:13 AM |
