Old 03-11-2010, 04:22 PM
Southern Charm Southern Charm is offline
Default I/O Noob Questions
I am new to Pro Tools, and I am having a bit of a hard time configuring everything. I purchased an MBox 2 with Protools 8 LE, and I am not able to get signal from my mic. I have made sure my phantom power is engaged, that record is engaged on the audio track, and still, it picks up nothing when I record.
I was able to use a midi controller to use some virtual instruments but I can't seem to figure this out. Please have some patience with me
Old 03-11-2010, 04:27 PM
Craig F Craig F is offline
Default Re: I/O Noob Questions
read over I/O in the manual
I'm guessing you don't have the correct input set up
Thank you,
Craig
Old 03-11-2010, 04:34 PM
Bender Bender is offline
You have to select the input you are using in the Mbox on the mix channel your using to record.
Old 03-11-2010, 04:41 PM
i am plugged into input 1 thru an xlr.. but under inputs i dont see the mbox. i will read the manual. thanks.
Old 03-11-2010, 07:31 PM
Go to Setup>I/O>Input tab and click on Default. In that window you can see what the inputs are called(you can also rename them here). Check the Mic/DI switch on the Mbox. You are using the XLR input?(phantom does not work on the TRS inputs).
Old 03-11-2010, 10:45 PM
yes i am using xlr. i am am recording with a shure sm27 condenser
Old 03-11-2010, 10:53 PM
the green led is lit up under "mic" on the mbox interface... what should i have the in and outs be on the track?? i reset the IO settings on the drop down menus and went to record again, and nothing.
Old 03-11-2010, 11:27 PM
call me an idiot but i cant even hear the metronome click... i am really new to this and would appreciate any help and maybe a walk thru from someone with some great patience lol
Old 03-12-2010, 12:54 AM
youngas75 youngas75 is offline
As Albee said, check your i/o settings. Once you have that ok create a new mono audio track. On the input section, the top one of the 3 rectangular boxes over your pan, make sure that it is set to 'IN 1' Record arm the track and turn up the gain on your MBox input until you see a good level on the new audio track. record that and take record arm off and that should be it I think. It's odd describing it from the office and not the studio! There is a Pro Tools 101 book available which you would probably find very, very useful as you are new to it. It will detail all the basic procedures for you and would get you on your way.
6 x HDX
21 x Vanilla
D-Command ES
S6 M10
SSL Duality, AWS924, AWS948, Nucleus
All Mac
Old 03-12-2010, 11:02 AM
thank you i plan on getting this book
imac Dual core 8gb 500gb HDD, Snow Leopard
mbox 2 PT LE 8.03
Axiom 49 Midi Controller
Shure Sm27 Condenser
Two Noob Questions... Tom Hartman Eleven Rack 4 05-01-2011 12:17 AM
some noob questions. ultimateguitarfish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-19-2010 07:53 AM
nOOb HD1 & PT7 questions, please help Andrew Bacon Tips & Tricks 2 10-26-2006 03:32 PM
Noob questions rezzy333 Pro Tools TDM Systems (Mac) 1 07-17-2006 01:22 AM
*Noob* I have a few questions K-OtiK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-01-2006 09:19 PM
