Old 01-15-2008, 11:35 AM
jccrtv jccrtv is offline
Default What is the setting to record from cursor?
I'm having a "senior moment". What is the setting to continue recording from where I've stopped the cursor (instead of automatically recording over my take from the beginning)?
Old 01-15-2008, 12:22 PM
weso33 weso33 is offline
Default Re: What is the setting to record from cursor?
Go up to Setup, then click Preferences. Within Preferences, go to the Operation tab and check the first box under "Transport" that says, "Timeline Insertion/Play Start Marker Follows Playback"
Then you should be good to go!
Paul
"It's locked when it's stuck to the 35 MM Print.
Until then..." - - Dr. Sound
pt hd 9.0.5
mac os x 10.6.7
2 x 2.66ghz dual core intel
7gb ram
fibre drives via facilis terrablock
video out - sdi mojo
Old 01-15-2008, 12:45 PM
Thank you Paul, that's exactly it. Kind of embarrassed about an easy one like that but I just couldn't remember, even after looking right at that check box.
Old 01-15-2008, 12:47 PM
RobMacki RobMacki is offline
or "N" in commands focus mode
7.4 Cursor Playback & Record Weirdness - New Feature... The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-13-2007 11:36 AM
Bug or Setting?? (Cursor related) Snafu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-26-2007 10:55 AM
scrolling cursor during playback/record david holmes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-24-2004 06:00 PM
Setting up a record label... Pro Tools User General Discussion 1 03-17-2004 06:41 AM
Setting up to play a bit before record CrAkD Tips & Tricks 1 02-28-2004 01:34 PM
